Alright so the computer is an old Dell Dimension 8400 running XP. It was getting a "battery voltage low" message and saying press f1 to continue, however the keyboard didn't seem to be responsive.
We can another coin battery or the same type and 3 volts lieing around so I went ahead and popped that in, and went to reboot. Now it goes through BIOS, and gets to the windows failed to start screen (one with options to boot into safe mode). Whenever attempting to boot into Windows it goes to blue screen, talking about runing chkdsk in case of corrupt hard drive and throwing a STOP: 0x0000007b (and then 3 pointers in parenthesis, can check what if it means anything to someone).
Now what makes this problem annoying is the laptop still is not responsive. It is a stupid wireless one, (new batteries, and when the sync button on the bottom is pressed the receivers light does go off) and no presses seem to go through. So I cant check BIOS settings, run a disk check, or even try to boot in safe mode, as the keyboard just won't work.
I really do not know how to proceed at this point. The computer is old and not used much so I am about to just yank the hardrive and copy that onto an external, but I would like to recover the computer if possible.
