Corsair PSU problem with Asus GTX 560 ti dc2
Hello,
i have the weirdest problem with my rig.. and i think is a combination of GPU + PSU.
Started to notice some really faded scam lines whenever i started a Game(any), like a interference or a old crt mhz difference. this only appears with whenever i open a Game, i was told this problem could be because of my monitor´s adapter is VGA to DVI... (weird but starting to believe)
some tests i made:
tryed 3 Psu´s :
Corsair tx650v2
Corsair cx600v2
Nox Urano 600w
2 different monitors(VGA with adapter) plus a LCD(HDMI)
2 Graphical Cards :
Asus GTX 560 ti dc2
Asus GTX 670
2 boards
with both corsair Psu´s + both Boards + Both GPU´s + VGA Monitors (using different adapters) - i always see this thin lines...
with both corsair Psu´s + both Boards + Both GPU´s + LCD(HDMI) TV - Works Fine without any line...
till here i started to believe that the problem was on VGA - DVI adapter ... But tried different PSU:
with Nox psu + Both Boards + Both GPU´s + VGA Monitors (using different adapters) - Works Fine without any line...
Don´t know what to do... can anyone give me a tip on this problem...
Edit: tried a older gpu saphire hd 5750 with the same configuration (Corsair Psu + Vga Monitor) - working fine..
thx in advance ..
Deemo13 said:
It's probably the monitor to be completely honest. What monitor are you using?
Heyas and thanks for the reply,
well i hv a hpw2007v
and i tested with other brad new samsung that i have @ work .. both working with all other pcs.
luciferano said:
If the Nox PSU works with this, then is there a reason that you can't use it from now on?
well the nox psu has only a 24 + 4 pins and i bought the corsair cause it has 24 + 8 pins to fully power up the board, besides the nox only has one sata strip and can´t reach combo cd writer. (need an adapter for that)
Ask the community
