Closed Solved
First build graphics card help!!
can someone help me tell the difference between the two besides the prices?
whats you favorite grafics card brand? best warranty?
is it better to get a 7870 because of the price?
Thanks!
sapphire 7950
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006
msi 7950
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127667
4 answers Last reply Best Answer
More about first build graphics card help
  1. Best answer
    I would go for the Sapphire 7950. As far as my system the Sapphire cards are the best I have had Sapphire cards since the Sapphire HD 3850(agp) and they are all still running strong in different systems. As for the 7950 vers. 7870 I would get the 7950 if you can afford it as it is a faster card and will serve your need longer before you would need to update.
  2. Best answer selected by awesomedude911.
  3. The title of this topic has been edited by Area51reopened
  4. This topic has been closed by Area51reopened
Radeon Graphics Cards Build Sapphire Graphics
