Hey so I just got the 7870 and noticed that when I run the fans at 80% or higher it kind of pulses? I don't really know how to describe it but it kind of pulses and is not steady. Is that normal?
It doesn´t seem to be normal -- as you have just got it, then try to describe the symptoms to the card manufacturer. If there is a problem, then you can RMA it, and get a new one.
it's what i feel on my case (the vibration increases then decreases at a pretty fast and steady pace) when i get the time i'll check it in afterburner later
okay on afterburner the fan speed is anywhere between 3990 and 4540 rpm but still the pulsing feels very weird i have an uneasy feeling about it like what jemm said
