Sign-in / Sign-up
Help with my build options and gpu!
  • New Build
  • Systems
  • Product
Last response: in Systems
Anonymous
November 22, 2012 1:41:10 AM
Hi guys, my first post here, and I'm planning to build a desktop for school. I'm planning on using it for video encoding and gaming. I don't plan on running over 1080p and I have a budget of under $2,000. I need some explanations of the cooling and what is the best. I want a pretty silent system but great performance. I was wondering how much video encoding performance the i7 offers over the i5. I'm open to all suggestions as I don't know much about the desktop world. The system is gonna be built in February. So my plans so far. I'm also looking for a good blu ray drive under $80
PSU: Corsair Pro Gold AX850 - http://www.amazon.com/Corsair-Professional-Series-Modul...
CPU: i7-3770 - http://www.amazon.com/Intel-Core-i7-3770-Quad-Core-Proc...
Motherboard: ASUS P8Z77-V DELUXE - http://www.amazon.com/ASUS-P8Z77-V-DELUXE-Intel-Motherb...
Fan: Cooler Master SickleFlow - http://www.amazon.com/Cooler-Master-SickleFlow-Computer...
RAM: Kingston Hyper X Genesis 16GB Kit (4x4GB Modules) 2133MHz - http://www.amazon.com/Kingston-Genesis-Modules-2133MHz-...
C Drive: OCZ 256GB Vertex 4 - http://www.amazon.com/OCZ-Technology-2-5-Inch-Industrys...
D Drive: Western Digital 1TB Black - http://www.amazon.com/Western-Digital-Caviar-Internal-D...
Cam (I want the best under $50): Logitech HD Webcam C525 - http://www.amazon.com/Logitech-Webcam-Portable-Calling-...
Speakers (I want the best under $50): Creative Inspire T12 - http://www.amazon.com/Creative-Inspire-Multimedia-Speak...
Monitor: ASUS ML249H 24inch LED - http://www.amazon.com/ASUS-ML249H-24-Inch-Monitor-Black...
Keyboard: Logitech Wireless Illuminated Keyboard K800 - http://www.amazon.com/Logitech-Wireless-Illuminated-Key...
Mouse: Logitech Wireless Anywhere Mouse - http://www.amazon.com/Logitech-Wireless-Anywhere-Mouse-...
GPU: The highest setting would be 1080p and I just want it to look good. I was thinking about either the Radeon HD 7970 ( http://www.amazon.com/Gigabyte-Radeon-Mini-Displayport-... ) or the GeForce GTX670 ( http://www.amazon.com/EVGA-Dual-Link-DisplayPort-Graphi... )
I was also wondering if we could get aero back on windows 8.
I'm dying for feedback. Thanks!
More about : build options gpu
November 22, 2012 2:48:09 AM
TheBigTroll said:
system is going to be built in feburary= you ask in feburary. its pointless asking now.
not going to explain every part that you chose wrong since its either overkill, or you can do better
assuming you are not going to overclock but going to do SLI
http://pcpartpicker.com/p/oJIf
monitor
http://www.amazon.com/AOC-i2367Fh-23-Inch-Screen-Monito...
CPU: xeons work fine in consumer boards
um...ok. he just wants some suggestions. whatever...
anyway, yes, in my opinion that's a decent build. it's just...you don't need to spend that much on it. granted, you could collect the parts one by one as they go on sale through february, but a couple things are a bit overkill. The PSU, for example, doesn't need that much power. you could get something like this...
Just like me!
The motherboard is also a bit much I think. what interests you in it?
And you gotta give it to the 7970, it's a beast right now.
m
l
Anonymous
November 22, 2012 3:06:15 AM
Thanks for the feedback. I wanted the 850 watt because the efficiency of it is rated much higher when using around 50% of the load and it has a great warranty. Plus I might add more things to the system in the future. The motherboard is just a beast and it have everything I can think of. I feel like it'll be more future-proof. I heard the i5 offers better gaming over the i7. Is this due to hyper-threading which you can turn off? Also what do you guys think about windows 8. I hate metro on desktops but it seems more powerful. I was planning to buy an ssd from best buy on black friday sale. 240gb for $120 - sandisk extreme?
m
l
November 22, 2012 9:34:18 AM
the 850w is useless if you are not going to load it at 50+ %. its less efficient if you dont hit those marks.
i wouldnt get the rosewell capstone 550w any day. the xfx 550w is just fine and is 20 bucks cheaper
future proofing is impossible. 1155 is at its end. not too much point putting a ton of money into it
they are about the same. you can always turn it off in the bios if you dont like it
its not more powerful. get 7
sure go ahead but you will have to camp out for the prices
m
l
November 22, 2012 12:56:48 PM
Care to explain why? Why u in such a mood troll?
m
l
November 22, 2012 2:26:40 PM
the 20 dollar increase from a 80+ bronze to a 80+ gold isnt worth it. they are like only3-5% more efficient from each other and its not like the xfx is anywhere near crap.
m
l
November 22, 2012 4:15:06 PM
I dont mean to be a butt, but being 80 plus gold isnt the only difference...
m
l
Anonymous
November 22, 2012 4:53:01 PM
The 7 year warranty is also great for the Psu so its worth it. but your right about the mother board I could go for a cheaper one (under $200). I'm wondering if the i5 should be enough for everything i'm gonna do. Is there really that big of a difference for video encoding? I think I'm fine without the second drive. I could go with a cheaper screen too.
m
l
November 22, 2012 9:43:09 PM
video encoding = no
video rendering 30% increase from what i know
since when did rosewell have 7 years of warranty
m
l
