Hello!
I'm looking to upgrade my PC, but not overhaul it completely. I'm looking to upgrade the Motherboard, CPU, GPU, and RAM, so I need to know if these are compatible with each other, and if they'd work with what I already got. Sorry, I'm not very... savvy, when it comes to the hardware aspects of these things.
So this is what's going on.
My PSU is a Corsair 650W, and I'm looking to upgrade into the following:
GPU: 1x http://www.newegg.com/Product/Product.aspx?Item=N82E16814130826
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
RAM: 1x http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568
And I'm curious to know if these parts will be compatible with each other, as well as work on a 650W PSU. The case I have is a mid-size Antec 900, so I'm thinking everything will fit into it, my only concern is compatibility.
I'd be pretty redfaced if the GPU wouldn't work with the Motherboard, for instance.
Thanks!
EDIT: My budget is $700 or less. The listed amounts up to about $660, that said; if any of my choices could be bettered in this budget range, let me know. I know sometimes that GPU's have older versions that are just about as good as their newer counterparts for cheaper, and I'd be very interested in that, if that's the case here.
I hear that 16GB of RAM tends to be overkill, if this is true, perhaps someone could hit me up with an 8GB that'd do the job just fine?
Thanks again.
Thanks!
Thanks again.
