Hay this is my secound build and i was wondering if all these parts line up im building a desktop for my mom very limited budget so here are all the parts
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118067
Cd/dvd/rw
http://www.newegg.com/Product/Product.aspx?Item=N82E16811148047
Case/480 psu
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145564
Hdd/500gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135315
Mobo its a micro http://www.newegg.com/Product/Product.aspx?Item=N82E16814161427
Gpu radeon 7750 2gb a little over kill for the build but it was realy cheap
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148543
8gb ram again a little over kill but realy cheap
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
Cpu amd atholon quad 3.0ghz 95 watts
Cd/dvd/rw
Case/480 psu
Hdd/500gb
