Tom's Hardware > Forum > Mobility Brands > Nokia > 6230 long life battery
Forum Mobility Brands : Nokia - 6230 long life battery
Archived from groups: alt.cellular.nokia (More info?)
Hi Guys
Just bought a 6230 and need to know where I can get a super dooper long life
battery for the 6230.I don't find the one supplied lasts very long when playing
around with the phone.
Thanks
SD
Sponsored Links
On Wed, 22 Dec 2004 01:38:37 -0600, sammyD <sdnone@none.com> wrote:
>Hi Guys
>Thanks
>SD
Have you tried the N Gage QD BL-6C which has more capacity
Chris P Bacon
Reply to Anonymous
>>Hi Guys
>>playing
>>Thanks
>>SD
>Chris P Bacon
Thank you, I shall look into this.
Stupid question but is this interchangable without causing problems into the
6230 as its for the NGAGE yes?
And how much greater capacity has this battery.I hope someone brings out a
longer life one soon for the 6230.
Anyway
Thanks
sammyD
Reply to Anonymous
On Wed, 22 Dec 2004, at 01:38:37 [GMT -0600] (18:38:37 Wednesday, 22
Did you follow the instructions in the manual re charging / discharging the
battery when new?
We are Pentium of Borg. Division is futile. You will be approximated.
Reply to Anonymous
>Anyway
>Thanks
>sammyD
Its a straight forward swap. I think it has around 200mAHrs more
capacity. Check Nokia's site - Nokia, Phones, Enhancments, Power,
Battteries
BL-5C at 850 mAh compared to BL-6C at 1070mAh
Chris P Bacon
Reply to Anonymous
>>playing
>battery when new?
Hi
Yes I did. In fact the saleskid who had one in the shop said to leave it on
12-15 hours (which I did) yet the manual actually only says 1.5 hours.
I think the main problem is the amount I have been using it.ie continuously
practising with images, texts and phone calls.As well as connecting it up to
the computer et al.So its clearly a me problem but I still feel the battery is
inadequate for the phone, but Im not an expert.
Thanks
sammyD
Reply to Anonymous
>>Anyway
>>Thanks
>>sammyD
>Battteries
>Chris P Bacon
Hey thanks for the help.
I shall certainly give that battery a try after the holiday is over.
Regards
sammyD
Reply to Anonymous
On Fri, 24 Dec 2004, at 15:59:41 [GMT -0600] (08:59:41 Saturday, 25 December
Four hours is sufficient, but you should have (maybe you did?) fully
discharge & recharge at least three times, to get ultimate battery use.
There are two things on earth that are universal: hydrogen and stupidity.
Reply to Anonymous
How do you fully discharge?
I tried to discharge by leving the radio on over night. In the morning,
the phone was off, but I wonder if the battery gets completely drained
this way.
I have noticed, that when the battery gets low, the phone refuses to
start non-essential functions, like Radio or MP3 player. That's
actually a good idea, I think.
But could it be that the phone shuts off prematurely when the battery
gets low while a non-essential function is running? This would leave me
with a low, but not a completely drained battery.
Comments?
Reply to Anonymous
> Four hours is sufficient...
Well, after less than two hours, the phone obviously stops the charging
process, as the animated charge bar disappears. I hav always
interpreted this as the phone's smart way to avoid battery damage
(overcharging).
If this interpretation is correct, what difference would it make to
leave the phone on the charger for four or more hours?
Reply to Anonymous
On Sat, 25 Dec 2004, at 12:37:05 [GMT +0100] (22:37:05 Saturday, 25 December
Just start the phone again in this condition, run whatever until it stops
and shuts down. After a few times the phone will not even start, in which
case the battery is then fully discharged.
Reply to Anonymous
On Sat, 25 Dec 2004, at 12:41:54 [GMT +0100] (22:41:54 Saturday, 25 December
> (overcharging).
According to a drone in Nokia service (in Australia) on initial charge the
battery bar is inaccurate. Battery cannot be overcharged.
On my old 6310i initial charge was 12 hours, and 24 recommended.
Women do come with instructions; ask them.
Reply to Anonymous
The other day I read a description how to make a long life rechargeable
battery for all kind of systems. One can use cheap rechargeable batteries
and one can make the capacity and the voltage whatever you want. You have to
use a simular plug of course but as Nokia always uses the same plug, most
people have one extra available.
Kind regards
Jan Wim
"sammyD" <sdnone@none.com> schreef in bericht
news:p5mdnd2heJ3guVTcRVn-tA@nildram.net...
> Hi Guys
> life
> playing
> Thanks
> SD
Reply to Anonymous
There are 1302 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
