HP nc4000 missing driver device - wireless card
kirstentoh
7
can someone help? wireless stop working after XP reinstall. says no driver installed but I cant find anywhere on hp website or any other sites the driver and do not know who is wireless adapter manufactuere where i can download the copy.
would appreciate any help.
kirsten
kirstentoh
7
Hi,
thanks for your help. i downloaded the above pack and installed it but still not luck with the wifi adapter. Win 7 still tells me driver for my wifi is not installed on my NC4000. wifi was working prior to reinstallation.
any other suggestion would be helpful. otherwise, i maybe just have to go out and get a new usb wifi adapter. just that it would use up a USB port and this laptop already has limited usb ports.
thanks all.
kirsten
