First system to be built from scratch
I just wanted to check in here and see if anyone notices any conflicts that might arise. Everything I've looked at indicates all the components should work together but better to check with you guys that really know these parts. Any comments on the configuration are welcome also.
A couple questions:
At some point I want to add a second video card will that power supply handle both?
I don't really know anything about HDD and SSD working together. Whats the best way for me to set them up? The computer is primarily for gaming and I tend to play a lot of them so putting games on the SSD doesn't seem like a good idea.
The PC:
Processor: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
Motherboard: Intel BOXDZ77GAL-70K LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Memory: Kingston HyperX Blu 16GB Kit (2x8 GB Modules) 1600MHz 240-pin DDR3 CL10 Desktop Memory KHX1600C10D3B1K2/16G
Case: NZXT Crafted Series ATX Full Tower Steel Chassis - Phantom
HDD: Seagate ST2000DM001 Barracuda 7200RPM 2 TB SATA 6 GB/s NCQ 64 MB Cache 3.5-Inch Internal Bare Drive
SSD: Kingston HyperX 3K SH103S3/120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
Graphics: EVGA 03G-P4-3661-KR GeForce GTX 660 Ti 3GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
DVD: Lite-On LightScribe 24X SATA DVD+/-RW Dual Layer Drive IHAS424-98 - Retail (Black)
Power: Corsair Enthusiast Series TX 750 Watt ATX/EPS 80 PLUS Bronze (TX750)
1 answer Last reply
More about first system built scratch
Homebuilt Systems
