New $1100 developer/Programmer machine. Review & sugestions requested
Hello everybody,
I have been trying to build a new developer machine. Suggestions and opinions requested.
Approximate purchase date:Next two weeks
System usage : Programming
Typical softwares that will be running all the time: Java, Eclipse IDE, Dreamweaver 5.5, Firefox, Chrome with 5 to 6 tabs each, Filezilla, Outlook, Cobian backup 10, Skype, Bit Defender total security 2012, Freemind, Adobe reader, Mysql workbench, Dropbox, Evernote, Windows media player, apache, mysql
Budget : Around $1100
Parts not required: OS, Optical drive, Keyboard and Mouse
Preferred website(s) for parts: doesn't matter, I live outside the US. Will be buying from a local store.
Country: India
Parts preference: Intel
Overclocking: Not sure
SLI or crossfire: Not sure
Monitor resolution: 2 x 1920x1080
Additional comments: This machine is going to be a developer machine . Will be used solely for development. No gaming. Movies/Videos watching - sometimes
Questions : 1. Overclocking - Z77 or H77. Should I go for a overclocking processor, mobo or a non overclocking one, given my needs? I will be spending long hours on code. I want the machine to be absolutely stable and not conk off suddenly due to overclocking. I do want this machine to run around 5 years if possible, before I replace it with a new one.
2. RAM - Should I go for 8 gb memory or 16 gb. Currently I am leaning for 8gb as I am running the same software's on a 1 year old system with core i5 2500k, Asus P8P67 and most of the time the memmory is at 35%?
Parts:
Processor : Intel core i5 3550 3.3 Ghz
Motherboard : ASRock H77 Pro4/MVP LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
Graphics card: No idea. Suggestions requested.
Primary Hard Drive (SSD): Corsair Force Series GS Red 240GB
Secondary hard drive: Western Digital WD Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
CPU cooler: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1
PSU: CORSAIR TX Series CMPSU-650TX 650W
Cabinet: Cooler Master CM 690 II Advanced Mid Tower Cabinet
Fans: Corsair Air Series AF140 Quiet Edition CO-9050009-WW 140mm Case Fan and
COOLER MASTER SickleFlow 120 mm
Note: Primary HDD will be used for dual booting (Windows 8/Ubuntu) and running the Eclipse and other programs
Thank you for looking into my specs.
3 answers Last reply
More about 1100 developer programmer machine review sugestions requested
  1. if it is for just developing then an i7 can do wonders for Multithread, but it is pretty pricey so i would opt for an AMD FX 83**, it has 8 cores and could compare to an i7 3770k in multi thread applications.
    no need for WD black, just get Seagate 2TB HDD for $70 and get this SSD instead
    http://pcpartpicker.com/part/ocz-internal-hard-drive-vtx425sat3256g
    cheaper and just the same performance
  2. @boulbox. Thanks for the HDD and SSD tips. Haven't looked into AMD mobos. Will go through them.
  3. a nice budget one is FX 83** series for programming
New Build Systems Product
