Hi there, I was just wondering if anyone could answer my question. I have two old vga monitors and would like to dual screen but my motherboard only has 1 vga port. Also I don't want simply two screens showing the same image but two separate ones so I can drag and drop etc. There is also a hdmi and a DVI-d port so would I be able to dual screen if I bought a hdmi to vga adapter like this:
http://www.amazon.co.uk/Premium-HDMI-Cable-Gold-Metre/dp/B000GDI6FC/ref=sr_1_1?ie=UTF8&qid=1348950269&sr=8-1
The reason I'm asking about hdmi to vga is that they seem to be cheaper and more easily available than vga to dvi-d adapters.
My specs:
CPU: Intel 2120
Mobo: MSI B75A-G43
RAM: 8GB Corsair Vengeance LP
(No GPU)
Thanks for your help!
James.
My specs:
CPU: Intel 2120
Mobo: MSI B75A-G43
(No GPU)
James.
