A good power supply for this build?
Can anybody recommend a good power supply for this build
http://pcpartpicker.com/uk/p/p79U
There no budget but don't want to be very high in price.
11 answers Last reply
More about good power supply build
  1. Get a 800w PSU, Seasonic, XFX and most Corsair are good, just check the reviews beforehand, depends wherever you want to spend extra and get modular or not really.
    Why not just buy a GTX 670?
  2. ^ 800W is waaaay to much. 700W at most
    Because looking at benchmarks 2 gtx 660s beats a gtx 680. Isn't 800watts to much?
    I thought 650 would be enough
  5. I just bought this PSU earlier today: Seasonic X750 for $89.99. The 650 watt is $79.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087
    Seasonic quality, nearly silent, gold certified, and modular. What more could you want?
  6. I'd go with 700 or 750 to be very safe.
    Also, keep something in mind... the 660s are only better in games that support SLI. Most of the games that are badly optimized and thus have bad performance? Aren't going to support SLI. The general consensus is to not ever sli low-end cards, because when you can't use them, you're running on a low end card.
    Yes. They have better oomph. But graphics cards are about SO much more than raw oomph.
    A good quality 650W unit will be enough.
    nVidia GeForce GTX 660 & SLI: 295.0 Watts - http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=844&page=17
    GTX 670 is so much money, losing at benchmarks bf3, skyrm, max Payne Ect all support SLI and are double the fps nearly with these gtx 660s. Nvidia I think now are really good adding support for SLI in games.
  9. Not for much more fps, the 670 can be bought with less money, when certain recent games that will not support sli the 670 will be better, besides the sli setup is more for 1200p gaming, you probably will play at 1080p.
    If you want latter on you can sli the 670.
  10. PSU's lose their ability to generate their rated wattage over time. Get usually about 100 watts more then what you think is enough for. Who cares about an extra .30 cents a month on a bill. It will keep your computer going longer then one recommended one now.
Build Power Supplies Systems Product
