Need help
Hey guys I'm looking for help with building a pc.
Would anybody hint me with recondmendations?
1tb hard drive
8 or more ram.
A good graphics card for running high response games
A compatible motherboard and CPU
I have a power supply already and a case
This will be uses for gaming and multi tasking making movies and animatics.
Thanks for help :D
3 answers Last reply
More about need help
  1. If you look at the bolded sticky in the homebuilt forums, check out the form - fill it out.
    What case do you have? What power supply?
    What games do you want to play, at what resolution (or do you need a monitor), and what do you think "high response" games means?
  2. I could go with any case or powersly recommended I would rather not use the case I have. The reason I didn't define the games was because ei play a wide verity of games but I would mostly play games that would pull a lot out of the computer... Soo yah....
    (My typing is weird because of autocorrect.... iPad..)
Homebuilt Systems
