Archived from groups: alt.cellular.nokia (More info?)
hey i was wondering
if any one can help me
i have a belkin bluetooth usb card for my laptop
i installed the Nokia PC Suite 5.8 software for my 6820
but i cant seem to get the connection managar to pick up
the phone..
has any one any ideas r have had any of the same problems
"Shaggyh" <shaggy_ohynes@ntlworld.ie> wrote in message
news:8PMyd.1$OP5.0@newsfe2-win.ntli.net...
> hey i was wondering
> the phone..
> all help and comments needed
> thanks
> regards
> shaggy
I have a similar problem using a Smart Modular bluetooth dongle with WinXP
on my desktop pc.
Nokia PC Suite refuses to see the bluetooth connection and i'm having to use
a USB cable for data transfers.
When i first got the bluetooth dongle it worked perfectly with PC Suite -
but after a reinstall of WinXP it's no longer detected.
I've tried the latest drivers for my bluetooth dongle, and also reinstalled
the bluetooth dongle and PC Suite but it's not working together.
"Martin" <zedolf@o2.co.uk> wrote in message
news:3322roF3rcu2aU1@individual.net...
>> hey i was wondering
>> the phone..
>> thanks
>> regards
>> shaggy
> on my desktop pc.
> use
> reinstalled
> Martin.
ya i no what ur talkin about, i had to reinstall the pc suite cos one of the
apps wernt working
so any one got any ideas? out there??
news:QK1zd.689$8Y5.468@newsfe3-gui.ntli.net...
> >> hey i was wondering
> >> the phone..
> >> thanks
> >> regards
> >> shaggy
WinXP
> > on my desktop pc.
> > use
Suite -
> > reinstalled
> > Martin.
the
> apps wernt working
Well i've now spent most of this afternoon trying to get PC Suite to detect
my bluetooth dongle with no joy.
I've now got two options...
1 - A new version of PC Suite is available for download from www.nokia.com it's version 6.41 and is newer than my current version so i'm downloading it
now.
2 - It seems that PC Suite isn't compatible with all bluetooth drivers.
A list of supported bluetooth drivers can be found on the PC Suite download
page - http://www.nokia.com/nokia/0,,54692,00.html - and my Smart Modular
Blue Opal dongle isn't listed as supported.
Windows XP SP2 has bluetooth support which may work with my dongle - but i'm
not keen on updating to SP2 as i don't have the time to fix any subsequent
problems. (I tried SP2 once and got fed up with all the work my pc needed
just to get something done).
Must i use the official Blue Opal drivers for my bluetooth dongle or would a
generic driver - supported by PC Suite - work i wonder...?
news:33692lF3ugkl3U1@individual.net...
>> >> hey i was wondering
>> >> the phone..
>> >> thanks
>> >> regards
>> >> shaggy
> WinXP
>> > on my desktop pc.
>> > to
>> > use
> Suite -
>> > reinstalled
>> > Martin.
> the
>> apps wernt working
> detect
> 1 - A new version of PC Suite is available for download from www.nokia.com > it's version 6.41 and is newer than my current version so i'm downloading
> it
> now.
> download
> i'm
> a
> Martin.
hey i installed that update the pc suite and that did the job
thanks 4 pointing that out
cheers
i hope ur problem is solved
just as easy as an updated verson of
the suite
