Need Gaming PC Build HELP!
Last response: in Systems
I've been trying to get all the parts together to create a new gaming pc for myself. I've spent hours looking for the best way to create a gaming pc. I found out about PCPartPicker. I started to use it and i think i have everything I need in order to create a pc. I do not want to spend over $400 on this PC. Please let me know if the parts I have are capable to run together. Thank you.
More about : gaming build
Oh my... that is.... much less than a desirable PC to even think about using. This is what I have whipped together for you...
As a matter of fact, I can't whip anything up for you as your budget is WAY to low. If it was $400 for the build, minus the monitors & windows, sure I could. But with it that likes only $220 for a gaming PC. With that amount of cash, you are looking at a very sluggish HTPC, not even anywhere close to playing much of any games at all.
BreadWhistle said:
Oh my... that is.... much less than a desirable PC to even think about using. This is what I have whipped together for you...As a matter of fact, I can't whip anything up for you as your budget is WAY to low. If it was $400 for the build, minus the monitors & windows, sure I could. But with it that likes only $220 for a gaming PC. With that amount of cash, you are looking at a very sluggish HTPC, not even anywhere close to playing much of any games at all.
if the OS is removed, what do you recommend i get?
Related ressources
- Need help build the first gaming pc - Forum
- I'm gonna build my own gaming pc for the first time, need help . - Forum
- Need Help with First Gaming PC Build ! - Forum
- Need help to build good gaming pc - Forum
- NEW GAMING P.C BUILD NEED HELP !!!!!!!1 - Forum
http://pcpartpicker.com/p/pdfX
If you want the monitor in your build, just don't crossfire the 7660D with the 6770. Getting rid of the extra video card should leave enough money left for your budget.
BreadWhistle said:
http://pcpartpicker.com/p/pd2DIf you want the monitor in your build, just don't crossfire the 7660D with the 6770. Getting rid of the extra video card should leave enough money left for your budget.
I don't have my own monitor at the moment. I just have a laptop, so I need a monitor in the build, so what should i do to keep the build at 400 with the monitor included?
BTW, you are doing your BBCode wrong. You have to place something between the ] and [ like Your Build or just post the link, as it's easier.
BreadWhistle said:
^^ You don't need a sound card. Drop that. Get rid of the PoS Logisys PSU, replace it with a CX430
Then get rid of the 6670, like I've said numerous times, and you should be right around on budget.
I did everything you said and now i have this http://pcpartpicker.com/p/pdL3
Is there anyway I could get a video card in there and keep it around $450?
I guess get this CPU instead
But I don't know if sacrificing so much CPU power for a video card is worth it though.
CPU: Intel Pentium G850 2.9GHz Dual-Core Processor ($70.05 @ NCIX US)
Motherboard: Biostar H61MGC Micro ATX LGA1155 Motherboard ($29.99 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($24.99 @ Newegg)
Storage: Western Digital RE2 500GB 3.5" 7200RPM Internal Hard Drive ($48.40 @ Compuvest)
Video Card: HIS Radeon HD 7750 1GB Video Card ($94.99 @ Newegg)
Case: Cooler Master Elite 431 Plus (Black) ATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: Antec EarthWatts 430W 80 PLUS Certified ATX12V Power Supply
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($15.98 @ Outlet PC)
Monitor: Hannspree HL193ABB 18.5" Monitor ($79.98 @ Outlet PC)
Total: $394.37
(Generated by PCPartPicker 2012-11-24 11:28 EST-0500)
Total: $394.37
BreadWhistle said:
I guess get this CPU insteadhttp://www.newegg.com/Product/Product.aspx?Item=N82E168...
Instead of sacrificing that much cpu how about this? http://pcpartpicker.com/parts/partlist/
DarkSable said:
BreadWhistle, keep something in mind... the A10 is actually a decent graphics card mixed with a cpu. If you pair it with very fast ram, it'll actually perform as well as the sorts of discrete cards you'd be using anyways.I know, but he is on a terribly tight budget, so I just thought I'd just use regular spec'd memory.
BreadWhistle said:
I know, but he is on a terribly tight budget, so I just thought I'd just use regular spec'd memory.I know that i should save my money in order to get a better video card, but what is a cheap and decent video card that I could use for a while until i have enough money for a better video card?
http://pcpartpicker.com/p/pdTt
Fwizzle said:
How does the PC specs made by milkshakez7z look to you? what do you think it is capable of running?It will run anything you throw at it really, BF3 multiplayer is the only thing it won't run, If you spent a little more on a 7770 you could get even better performance, also get the monitor with the 5ms respose time, DO NOT get the 16ms one, the few dollars extra are worth it.
milkshakez7z said:
It will run anything you throw at it really, BF3 multiplayer is the only thing it won't run, If you spent a little more on a 7770 you could get even better performance, also get the monitor with the 5ms respose time, DO NOT get the 16ms one, the few dollars extra are worth it.thanks for the advice
milkshakez7z said:
No worries , any questions just ask ^_^Well i got a question. I've been working on the perfect pc for my budget. I only want to spend $400 in total. This is the build I have so far http://pcpartpicker.com/p/piML I have $20 left over. What should I improve to make the PC better?
Fwizzle said:
Well i got a question. I've been working on the perfect pc for my budget. I only want to spend $400 in total. This is the build I have so far http://pcpartpicker.com/p/piML I have $20 left over. What should I improve to make the PC better?get this one, its faster in every way.
http://pcpartpicker.com/p/pe0M
is the power source in stock? it doesn't have a price by it
CPU: Intel Pentium G645 2.9GHz Dual-Core Processor ($49.99 @ Microcenter)
Power Supply: Antec 350W ATX12V Power Supply ($23.17 @ NCIX US)
Total: $397.48
(Generated by PCPartPicker 2012-11-24 22:11 EST-0500)
Total: $397.48
milkshakez7z said:
Yeah I kinda agree, You need at least $450 and that's not including a monitor, to build something good, but this is what OP asked for.I understand that it would be more ideal to have a larger budget, but i do not. I feel like the build I have right now gives me the most bang for my buck. Let me know how I can improve my current build http://pcpartpicker.com/p/pe0M
Fwizzle said:
I understand that it would be more ideal to have a larger budget, but i do not. I feel like the build I have right now gives me the most bang for my buck. Let me know how I can improve my current build http://pcpartpicker.com/p/pe0MAdjusted so you have a psu xD http://pcpartpicker.com/p/pkfa
Related ressources:
- ForumNeed help with parts to build a gaming pc
- ForumNeed Gaming /Streaming PC build help
- ForumBattlefield 3 Gaming Pc Build , Need Help
- ForumI need help on building a gaming pc from scratch?
- ForumI need help building a new and powerful gaming PC .
- ForumBuilding a gaming pc for the first time for around $2000 - need help
- ForumNeed help building first gaming pc
- ForumNeed help building a gaming pc
- ForumNew Gaming PC Build - Need Help Trimming Down Cost to sub-£700
- ForumNeed help building a budget gaming pc
- ForumNeed help building a gaming pc ?!
- ForumConsole gamer here looking to go into pc gaming need help with build
- ForumShould I upgrade my video card or hdd to sdd?
- ForumNeed help with Gaming PC Build
- More resources
The A10 will serve your needs as long as it has to - IT is your cheap and decent video card.
