I have a HP Pavilion p7 1054 with the following specifications;
Motherboard;
N-Alvorix-RS880-uATX (Alvorix)
Processor;
AMD Athlon II X4 645
Operating speed: Up to 3.1 GHz
Number of cores: 4
Socket: AM3
Bus speed: 4000 MHz HT3
Memory;
6 GB
Speed: PC3-10600 MB/sec
Type: DDR3-1333
Video graphics;
Integrated graphics using ATI Radeon 4200
Computer Case;
ATX
Height: 38.81 cm (15.28 inches)
Width: 17.50 cm (6.89 inches)
Length: 40.99 cm (16.14 inches)
Power Supply;
Internal 250W (100-240V)
Form factor: internal ATX
Total Wattage: 250W
Nominal input voltage range:
100-127V ~6A
200-240V ~3A
Dimensions: 150mm x 140mm x 86mm (5.9 x 5.5 x 3.4 inches)
What I'm buying;
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182133
Question is, will it fit?
Motherboard;
Processor;
Number of cores: 4
Socket: AM3
Memory;
6 GB
Type: DDR3-1333
Video graphics;
Computer Case;
ATX
Power Supply;
Total Wattage: 250W
100-127V ~6A
200-240V ~3A
What I'm buying;
