Tom's Hardware > Forum > CPU & Components > Sound Cards > Speaker balance problem.
Forum CPU & Components : Sound Cards - Speaker balance problem.
I'm not sure if this is a software issue or not...My speaker balance is moving over to one side on its own. I have a SB Live 5.1 card and am running Win XP.
I have tried reinstalling and updating drivers etc.
Anyone else having this problem?
Tia for any info.
Gary
Sponsored Links
I had the same problem using the driver that came with my SoundBlaster Audigy card. I bought it at the end of September. By the end of October a new driver was available for the soundcard. If you have already downloaded the new driver and software from Creative you have to uninstall the old driver and software before you install the new driver and software. Then the balance problem should be resloved.
<font color=red><i>Happy Canuck</i>!</font color=red> ' :wink: '
Reply to zpyrd
it's not soft
it's hardw
you don't plug correctly the audio wires
between your cdr & audio card
or not use the correct one
EasyInfo :cool:
I would like to Invest for my PC !!
ok, buy nothing.
Reply to labdog
There are 910 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
