I NEED TO KNOW WHAT GRAPHICS CARD AND POWER SUPPLY TO GET
Hello,
I JUST BOUGHT A GATEWAY SX2370-UR30P COMPUTER TO USE WITH MY GRAND VJ PROGRAM.I NEED TO END UP WITH A COMPOSIT SIGNIL OUT BECAUS ALL THE CLUBS USE COMPOSIT FOR THERE VIDEO PROJECTORS.THE HDMI TO COMPOSIT CONVERTER BOX I BOUGHT MAKES WINDOWS CRASH SO NOW IME LOOKING AT UPGRADEING TO AN EXTRA VIDEO CARD AND BIGER POWER SUPPLY HOPEING THIS MIGHT WORK,(I NEED TO KNOW WHAT KINDE TO GET FOR MY COMOUTER,,,)IF I COULD FINDE A CARD THAT WOULD FIT WITH A S-VIDEO OUT IT WOULD MAKE MY LIFE MUCH SIMPELER.
2 answers Last reply
More about graphics card power supply
  1. I NEED TO FIND CAPS LOCK KEY
    Other than that, go onto newegg and pick a card with tv-out. You probably want one with a PCIe slot.
    PSU wise you shouldn't need an upgrade as most of the cards with TV out are gutless.
  2. http://www.tomshardware.com/forum/283384-33-read-first
    "Dont...
    Post in ALL CAPS or use excessive punctuation!!!"
    Your computer is not going to be able to fit a regular power supply.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814139032
    This one should do the trick.
Graphics Cards Power Supplies Graphics Product
