Solved
New to ATI videocards. RadeonPro best settings help
October 1, 2012 6:35:26 AM
Hello everyone.
I recently purchased a hd 7970 3gb to replace my OLD gtx 450 from nvidia. I never had any problems with settings etc with my nvidia card all games would run great and I didnt have to mess around with the settings.
now I have this beast ATI card and I dont know how to control it, I can play battlefield 3 on highest settings with little frame drops always at 60 frames same with crysis 2 no frames lag etc. I even play starcraft 2 on extreme and the frames always are at around 50-60 on huge battles.
But here its my question for some games like minecraft, sexy beach zero batman arkaham city and arma 2 I get bad frames I wouldnt mind getting low frames if it wasnt noticeable but it is . I have downloaded Radeon pro to do global or per game settings for all games but I dont know whats the best settings to have on etc.
there are so many options and I do understand some of them but if you guys could help me save some time what are the best settings for RadeonPro profiles tool?
October 1, 2012 6:49:16 AM
It's an AMD card, not an ATI(bought by AMD a few years ago) card, first things first. ;)
Have you updated the drivers?
m
l
October 1, 2012 6:53:12 AM
yes sir all this time I thought ati and amd are same xD thanks for telling me I been going around telling lies and noone till now ever corrected me thanks again.
I had that nvidia card before so i deleted/removed all drivers from nvidia before I installed the amd catayst control center using 12.8 version.
PS idk where the heck I got ATI from...
m
l
October 1, 2012 7:37:34 AM
They used to be known as ATI before being purchased by AMD, so you are in the correct ballpark at least.
First thing I would check would be the antialiasing settings. Full-screen super-sample AA can create a big hit on fps, so make sure you turn it off both in the game and the Catalyst Control Centre.
Also, what is the rest of your system specification?
m
l
October 1, 2012 8:16:41 AM
would the games still look good? if I turn that stuff off? also I am using RadeonPro has lots of more settings which 90 % of them I have no idea what they mean, or Catayst control center is better?
Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
8.00 GB ram
SAPPHIRE HD 7970 OC 3GB GDDR5
Windows 7 64bit
m
l
October 1, 2012 8:26:04 AM
I've never used RadeonPro so I can't really comment on that. CCC now also has the capability to create application profiles, and that is what I use. I'm not sure how CCC and RadeonPro would interact with each other.
m
l
October 1, 2012 8:32:50 AM
radeonpro disables/overrides CCC.
but lets say i am using CCC what settings would you have for best quality yet still have good performance? all I need are some pointers on how to set it up, yes I know I can look it up but if you can help me save some time if you already know.
m
l
Best solution
October 1, 2012 8:58:00 AM
It really depends on the resolution you play at, but here some tips that I have found useful:
- Leave Vsync off in CCC; set it to use the application setting.
- If a game supports AA in its settings, then select it there rather than forcing it via the driver.
- If you force AA in the driver, use at most 4x MSAA (multi-sample). This is the sweet spot between quality and performance.
- Anisotropic filtering you should be able to set at 16x for all games.
Hope this helps.
October 11, 2012 4:16:16 PM
Best answer selected by noxturno.
m
l
