Solved
How bypass case power hookup
Hello,
I am try to hookup a motherboard outside of the case. There are 3 contacts in the m'brd PwrSw pin blocks: +5v, gnd, & pwr. I assume these are the only relevant pins ?
How should I connect these to power up the board ?
4 answers Last reply Best Answer
More about bypass case power hookup
  1. Best answer
    You see the pins in the bottom right where you would connect the cases power switch to? Get a screwdriver and short those pins, that will start the mobo.
  2. Or if you can get your hands on one from somewhere else a jumper would work too, put it on when you want the system on and take it off when you want to shut it down
  3. I traced the "pins on the bottom right" & saw that the power switch merely shorted the "pwr" pin to "gnd" to complete the circuit.
    Thanks for the clues.
  4. Best answer selected by love music.
New Build Cases Power Motherboards Systems
