Are these parts compatible?
Okay this is the build i am going to buy in 2 days just checking everything goes together okay and that the cpu is ready to run by the mobo and stuff http://www.scan.co.uk/savedbasket/9a9a0acd35a94741923d368bb3f58c08 :)
Also that case atm is all i can afford will it fit all the components?
thanks alot. :D
4 answers Last reply
More about parts compatible
  1. Yea, but it might be better if you get a z77 and a 3570k so you can overclock.
    Everything is compatible
  2. samuelohagan said:
    550w will run this system fine i think :P
    But besides that will this system all be compatible?
Build Compatibility Systems
