NEED BUILD REVIEW
abhop26
79
Please dont suggest the HAF912 as I already have it for another build.
Suggestions- I can only go cheaper. Have done 1 build before, making sure everything works together!
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1102935
http://www.newegg.com/Product/Product.aspx?Item=N82E16832416550
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235027
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Kiowa789
407
Ugh, Your lucky I have patience with people.
Fill out the form, then resubmit.
oh, and the PSU combo is unnecessary, get a 300-400w psu, then you can have money for the GPU.
If this is an extreme budget build, get a cheaper case, yes, it can get cheaper, especially with cooler master, (Zalman Cases are a no no anyway)
