Approximate Purchase Date: This Week
Budget Range: Around $800
System Usage from Most to Least Important: gaming, surfing the internet, watching movies
Are you buying a monitor: No
Parts to Upgrade: New System
Do you need to buy OS: No
Parts Preferences: Already purchased a Z77 board and an intel chip
Overclocking: Maybe
SLI or Crossfire: Doubtful
Your Monitor Resolution: 1920x1200
And Most Importantly, Why Are You Upgrading: Current puter is woefully out of date.
This will be my first build and I'm pretty sure on my parts outside of the GPU and PS. Here is what I have so far:
CPU:
Intel Core i5-3570K
Motherboard:
GIGABYTE GA-Z77X-D3H
Memory:
Patriot Viper 3 16GB (2 x 8GB) DDR3 1600
HD:
Western Digital Caviar Black 1TB SATA
Case:
Rosewill BLACKHAWK
PS:
SeaSonic G Series SSR-550RM 550W 80 PLUS GOLD
GPU:
XFX Double D FX-787A-CDBC Radeon HD 7870 GHz Edition Black Edition 2GB
Games I am currently playing:
Borderlands 2
WoW
GW2
Dragon Age 2
Skyrim
Assassins Creed 3 or Farcry 3 (depending on the GPU I get)
I'm hoping there are no bottlenecks in my build and everything will work together well. I'm still pretty undecided on the PS and GPU. I would like to be around the $300 mark for both of those together though I can push up another $50 or so if I need to increase either. I have been looking at these other cards as well:
GIGABYTE GeForce GTX 660 at $210 with a rebate
GIGABYTE GeForce GTX 660 Ti at $280 with a rebate
I kind of went in the middle with the 7870 based on reviews and Tom's Hardware value review. It is listed at $230 after rebate. Is it worth it to save a bit and drop down to the GTX 660 or go up in price to the GTX 660 Ti? I don't want to spend money that I don't have to but when I'm already dropping money on this build if the gains justify putting out some extra money I would do it.
Are there any bottleneck issues with this build or anything I have overlooked in making sure the components are compatible? Will the 80 plus gold 550W be enough or should I bump up to a 650W? Also with the price differences in the GPU's is there one with better value than the 7870?
This will be my first build so I'm hopeful that I've got some quality parts and that I haven't overlooked anything here. Thanks for any feedback or advice.
