New Build Gigabyte Z68AP-D3 with Kingston new HyperX 3K ssd problems
MrThunder
5
Hi,
This is my first post so thanks in advance for any help.
This is my first build and I am experiencing problems with it:
1. The boot time is very slow, it takes about 2-3min.
2. When I turn on the computer it gets past the first splash screen (giving you options to enter the BIOS) it shuts down and restarts up to five times in a row before finally booting windows.
3. My Kingston new HyperX 3K ssd is very slow when I run AS SSD Benchmark when compared to here. I think I have the SSD set up incorrectly and it is causing all my problems. I am using the SSD to run Windows 7 and the Western 1TB to store my files and an Ubuntu partition.
Are there any other steps I need to do to get it to work properly? So far I have the following settings:
TRIM - enabled
C3/C6 State Support Disabled in BIOS
PCH SATA Control Mode - ACHI
4. As a side (and not so important) problem my TP Link TL-WN881ND 300Mbps Wireless N PCI Express Adapter is terrible, i had to buy a wireless range extender which is now only ten feet from my computer and i only have 3 bars of signal and my laptop has full signal. I have the latest driver, any Ideas?
Intel i5 2500K
Gigabyte Z68AP-D3 rev.2 (latest BIOS ver. FD istalled with Q-flash )
Corsair 32GB 1600MHz CL10 DDR3 Vengeance Memory
Kingston new HyperX 3K ssd (with latest firmware Rev.503ABBFO, plugged into port SATA3_0)
Western Digital Caviar Green 1TB SATA III 6 Gbps Internal 3.5 inch Hard Drive (plugged into into port SATA3_1)
ATI Radeon HD 5450 graphics card Coolermaster Hyper 212 EVO
650W Coolermaster GX RS650-ACAAD3 80+ Bronze
Case -Fractal Design Define R3
Cheers :wahoo:
