Hi. I have a geforce2 mx/mx 400 video card with a Chrontel 7008 TV encoder chip (means i have TV/OUT capabilities). I am using a standard RCA composite video cable that I attached to the back of my video card and the other end to my TV set. Well actually my tv set and pc are about 15 ft. apart, so i used a 15 ft. satellite cable and rca video cable adaptors to "extend" the video cable.
I then activated TWINVIEW from Display Settings, but it doesn't detect the TV! I even went as far as downloading TVTool 5.5 (a software specially designed for TV/OUT video cards). It doesn't detect it either! I contacted my manufacturer, www.MDG.com, and he just said that i would have to replace the card! I don't think he knew about what i was talking bout! Does anyone have any ideas?!
Just for your info, I am running Windows XP Professional Build 2600. I also installed the Detonator XP v21.83 drivers from Nvidia. Would appreciate any advice.
System:
Intel P4 1.4 GHZ
256mb (2x128mb) RD-RAM
40 GIG hard disk
16x DVD-Drive
12x10x32 CDWriter
Sound Blaster Live! Platinum 5.1 sound card
Geforce 2 MX/MX 400 32 mb video card
System:
Intel P4 1.4 GHZ
40 GIG hard disk
16x DVD-Drive
12x10x32 CDWriter
