well it seems if im doing absolutely doing nothing sitting at the desktop after start up the pc only goes to a max of 20C(the graphics on the other hand goes up to 30-40C)
atm ive been on the internet for a hour and it says CPU#0 is 13C at a max of 24 min 12
but the GPU is up at 35C which is average.
and i do notice some lagg occasionly with minimal CPU usage.
could this be related to....
http://www.tomshardware.com/forum/378597-33-drivers-cra...
and
http://www.tomshardware.com/forum/293129-32-hard-drive-...
both happened to this pc and i have a feeling the hard drive could be failing.
but if your saying that a CPU should not be below 23C then why
is mine a min of 12? also what temp checker would u recommend?
btw ive been getting a sort of unresponsive mode occasionly.....
ill be just on my computer and it laggs for a moment then everything just stops
(this happens when the CPU is under 15C)
it only stops for a moment and its related to how the drivers crashed before.(1st link)
i would blame a virus but i dont think so because it started all the
laggin once i installed the 2 intake fans. (last monday)
also it seems my CPU temp is very vague on what it actualy is....
it will be 12C then randomly boost to 20's(it raised my max to 26 a second ago)
http://www.pcguide.com/care/care/gen/envAmbient-c.html
Spoiler
according to this link having a computer start realy cold can cause
the hardware to fail(is realy cold consider 12C or below?)
If you take a PC that is at freezing temperature and plug it in, it will warm up very quickly, much more quickly than it would if you left it on a table to warm up in its own time. In some cases, you can raise the temperature of equipment from 0 degrees to 150 in only a matter of minutes. As discussed here, thermal stress is a leading cause of premature failure of electronics components. This is bad enough when the components are raised from 70 degrees to 150; when they are raised from 0 to 150 it is much worse.
it seems i found this info from core temp themselves.....
Why is the temperature of my Phenom based processor lower than the ambient temperature?
Starting with the Phenoms, AMD's digital sensor no longer reports an absolute temperature value anymore, but a reading with a certain offset, which is unknown. It is estimated that this offset is between 10 - 20c.
i know mine is FX but could it be the sane issue?
if this is true then my actual temp is 32C which seem smore likely and should i take it like this?
and if thats true then that means my CPU use to run at 70C?
