So I have to choose between 2 motherboards, which one should I get? And will they both work with the build that I'll put below.
1. GIGABYTE GA-970A-DS3 AMD 970/SB950 AM3+ FX ATX Motherboard - ATX, Socket AM3+, AMD 970 Chipset, 2000MHz DDR3 (O.C.), SATA 6.0 Gb/s, RAID, 7.1-CH Audio, Gigabit LAN, USB 3.0, CrossFireX Ready
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2932738&Sku=G452-8442
2. ASRock Z77 Pro4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157296
The GIGABYTE one is about $40 less right now.
Now for the build it will have to work for (state any flaws I have or if anything will work better please)
CPU: ($170) Core i5 3570K 3.4GHz LGA 1155 Processor http://microcenter.com/product/388577/Core_i5_3570K_34GHz_LGA_1155_Processor
PSU: ($70) CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
RAM: ($40) G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
HDD: ($90) Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
Official Case: ($70) Z9 U3 ATX Mid Tower Computer Case http://microcenter.com/product/400425/Z9_U3_ATX_Mid_Tower_Computer_Case
GPU: ($230) MSI NVIDIA GeForce GTX 660 2GB GDDR5 PCI Express 3.0 Graphics Card N660 TF 2GD5/OC
http://www.amazon.com/MSI-GeForce-Graphics-N660-TF/dp/B0094CX8QI/ref=br_lf_m_1000832461_1_3_ttl?ie=UTF8&m=ATVPDKIKX0DER&s=pc&pf_rd_p=1399605342&pf_rd_s=center-2&pf_rd_t=1401&pf_rd_i=1000832461&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1FVWFHW0F7631Z8VP0F4
Optical Drive: ($20) LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 – OEM http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
-So will this be a semi-good build? I am mostly going to play games like BF3/4 (I'll be able to upgrade a bit by the time 4 comes out), Skyrim, Minecraft, and games like that. I don't need a whole lot of graphics, medium to high is fine for me because I am a console player. As for frames, I would like 30-40. Any feedback is welcome, thanks
