Will this custom build work together?
kassuba39
434
Hello I am new to building PC's and I was wondering if all these parts are compatible with one another. Also, if so, would this setup be able to run simple games like Counter Strike Source and Call of Duty 4?
Case:
APEX SK-393-C Black Steel $23.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154109
HDD:
Refurbished Maxtor 6L160P0 160GB IDE Ultra ATA133 $29.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822144518
Power Supply:
COOLMAX CA-350 350W ATX $25.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159042
RAM:
Patriot Signature 4GB 240-Pin DDR3 SDRAM DDR3 133 $18.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220480
CPU, GPU, and Mobo Combo:
CPU - AMD A4-3400 Llano 2.7GHz Dual Core, GPU - AMD Radeon HD 6410D, Mobo - ASRock A75M-ITX FM1 AMD A75 (Hudson D3) SATA 6Gb/s $128.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1101838
Thanks for your help, I think this is all compatible with one another but I'd like to make sure before I pay money on this.
everythings is compatible yes, but what is your budget? that build is very bad, yet counter strike is very easy to run :/ what is your graphics card int that equation?
kassuba39
434
I actually totally changed my mind on this, it hit me on how badly it sucked. I think I've got a better setup now. Would a AMD Athlon II X2 260 Regor 3.2GHz run well with a SAPPHIRE Radeon HD 6670 1GB? That's kind of gearing to be my new build.
kassuba39
434
I kind of already got a better idea. I realized how awfully wrong this was. Tell me what you think! AMD Athlon X2 Regon 3.2 Dual Core, SAPPHIRE Radeon HD 6670 1GB 128-bit DDR3, 4 GB Ram, 500 GB HDD. Should I give you specifics or does this look good?
