Power supply for 2 graphics cards
October 5, 2012 2:37:54 PM
i want to upgrade from 1 card to 2 and dont know what power supply will work and what motherboard will be compatible with my setup these are the specs please could you reccomend a power supply and a motherboard
Operating System
MS Windows 7 Home Premium 64-bit SP1
CPU
AMD FX-6100
Zambezi 32nm Technology
RAM
8.00 GB Dual-Channel DDR3 @ 669MHz (9-9-9-24)
Motherboar
ASUSTeK Computer INC. M5A78L-M/USB3 (AM3R2)
Graphics
HK241DPB (1920x1080@60Hz)
AMD Radeon HD 7700 Series
Hard Drives
932GB Seagate ST1000DM003-9YN162 ATA Device (SATA)
Optical Drives
TSSTcorp CDDVDW SH-222BB ATA Device
TSSTcorp CDDVDW SH-222BB ATA Device this was taken from a software from speccy
a b U Graphics card
October 5, 2012 2:49:51 PM
http://www.asus.com/Motherboards/AMD_AM3Plus/M5A78LMUSB...
If this is your board, then you only have one PCIe x16-sized expansion slot. You need two fo them for dual-card Crossfire.
A PSU such as the Corsair CX430 430W could handle 77xx CFX with a lot of room to spare. What you can do is upgrade to a better PSU if yours isn't good enough and you can sell your 77xx card to get a 7850 or 7870.
a c 275 U Graphics card
a c 147 ) Power supply
a c 261 V Motherboard
October 5, 2012 3:18:31 PM
May I suggest you reconsider your graphics upgrade strategy.
A 77xx is fine card. But adding a second card has some issues, which you have already identified.
In addition, dual card operation with lower strength cards may have some issues, including microstuttering and scaling.
Read this: http://www.tomshardware.com/reviews/radeon-geforce-stut...
When you add in the cost of a different motherboard, and perhaps a stronger psu, it will probably be better and less expensive to just sell your 77xx card and replace it with a much stronger single card.
Exactly what psu do you have now?
a b U Graphics card
October 5, 2012 3:27:31 PM
That review is irrelevant. This is a completely different micro-architecture. 77xx cards are actually good at Crossfire with minimal stutter and excellent scaling. I'm still recommending a 78xx card such as the 7850 and the 7870 because of the frame buffer advantage and they're slightly higher value, but still.
October 5, 2012 3:31:08 PM
i have a xigmatek 500w
a b U Graphics card
October 5, 2012 3:32:49 PM
I have no experience with Xigmatek PSUs and I'm not familiar with them, so I won't make claims about their quality. However, I will remind you that wattage doesn't matter much. The 12V amperage is what matters these days and it does not necessarily directly correlate to the total wattage rating. Can you give us the specs on its 12V amperage (or 12V wattage, some list it as 12V wattage)? That'd be on a sticker on a side of the PSU.
a b U Graphics card
October 5, 2012 3:52:14 PM
TheReckoning said:
tbh i dont know what you want to know (im kinda new to this )
so i went on google to find it http://www.amazon.co.uk/Xigmatek-NRP-VC503-500W-Power-S... this is it
oh that psu sucks
+5V 16.0A/0.3A
+3.3V 22.0A/0.5A
+12V1 15.0A/1.0A <------ 18A required for a HD 7770
+12V2 16.0A/1.0A
-12V 0.8A/0.0A
+5Vsb 2.5A/0.0A
Total Power 500W <----- Don't think its really rated for 500W
October 5, 2012 3:57:16 PM
should i just get the motherboard and psu you suggested and another HD7770 ?
October 5, 2012 4:03:03 PM
ok thank you very much
October 5, 2012 4:05:33 PM
I suggest you sell the 7770. It seems to go for $80-$100 on e-bay in used condition.
Replace it with a 7850 which is a considerable jump in capability. That will cost you about $170 which isabout what a replacement psu and motherboard will cost.
A 7850 needs only a 450w psu, so your current psu should be fine.
If you want a 7970 or GTX670 class card, I think you might want to replace the psu.
a b U Graphics card
October 5, 2012 4:07:03 PM
your very welcome :D
