Parts compatibility check, would this build work?
Hi,
I'm trying to build a cheap PC just for media editing and a little bit of gaming such as COD 4 etc. So nothing to powerful at all, although I do want it to be fast and efficient.
I've come across these parts and I was wondering if it is all compatible and would create the system I desire
PROCESSOR
http://www.msy.com.au/product.jsp?productId=9687
AMD x2 A6-5400K Dual Core 3.6Ghz FM2 CPU
MOTHERBOARD
MSI FM2-A55M-E33 FM2 AMD A55
http://www.msy.com.au/product.jsp?productId=9749
RAM
G.Skill Ares 8GB Kit (4Gx2) DDR3 1600 F3-1600C9D-8GAO
http://www.msy.com.au/product.jsp?productId=8835
CASE w/PSU
A-Power APWR-C-MGX2 Megatronx2 Case with PSU
http://www.msy.com.au/product.jsp?productId=9560
HARDDRIVE
Hitachi 2.5" TravelStar 500GB SATA HDD
http://www.msy.com.au/product.jsp?productId=2316
GRAPHICS CARD
http://www.msy.com.au/product.jsp?productId=9810
Gigabyte GV-R657D3-2GI 2GB 6570
What do you guys think, Thanks in advance
sorry for the repost no one helped in last thread
2 answers Last reply
More about parts compatibility check build work
  1. It'll work, but you're way better off buying a Phenom II x4 if you're getting a graphics card. That CPU is a CPU+GPU, so there's no point in it if you're getting a graphics card.
    Basically you have two way s of getting a decent rig that cheap:
    Phenom II x4 with an AM3/3+ board, and a graphics card,
    or
    AMD A10 / good A8 with a FM2 and no graphics card.
    Also, either way, buy a case and power supply separate - that power supply is very bad quality and likely to make the computer explode.
  2. thank you :)
Homebuilt Build Systems
