Using lcd tv as monitor how to hook uo
i need to know what cables to use to use my lcd tv as a monitor for my computer ... and a description of the cable please :hello:
3 answers Last reply
More about using monitor hook
  1. That depends on what ports it has. If it has HDMI and your computer has HDMI, then that's probably the best to use. Do either your computer or your TV not support HDMI?
  2. What is the brand and model of the computer's graphics card (if it's using a discrete graphics card) or integrated graphics processor if you're using that?
    What is the brand and model of the TV?
  3. It also depends whether you're connecting the two with a receiver, and whether you're using the TV speakers or a separate set of speakers connected either to the receiver or PC.
Nvidia TV LCD Monitors Cable Graphics
