Solved
Will an optical drive fit into this Micro ATX case?
I was just wondering if a CD drive like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Could fit into a case as small as this: http://www.newegg.com/Product/Product.aspx?Item=N82E16811322014
My guess would be no, since it doesn't seem like the case would have enough room for bays. But I just wanted to ask and be sure. If not, is there a way I could get an optical drive into that case?
Thank you for the help,
~Tyler
3 answers Last reply Best Answer
More about will optical drive micro case
  1. Best answer
    It will actually. The case supports one external 5.25" bay, and 5.25" is exactly what that optical dive is.
  2. I love Tomshardware. A fast and simple reply!
    Just what I wanted to hear.
    Thank you!
  3. It shoudl work yes, and welcome to the forums!
Homebuilt Cases Optical Media Systems Product
