GPU problem
Hi,
I'm new here.
I've a problem with my new graphics card.
I've a HP pc, that I've upgraded over the last months. Today I installed a new Graphics card: MSI GTX660 Twin Frozr and when I boot up. My screen stays black.
So I installed back my older GPU and my PC works fine.
Here are my specs:
i7 2400 3.4
PSU: Coolermaster GX700
SSD: Corsair 3 120GB
RAM: 16GB DDR3
Motherboard: IPISB-CH2 from HP
I tried everything, updated BIOS, changed the PSU,...
But still no screen, no bios, nothing
Hope you guys knows an awnser
Cheers
Miguel
3 answers Last reply
More about problem
  1. some of the msi cards were found to have a part that was out of nvidia spec.
    http://www.tomshardware.com/news/MSI-GTX-660-670-overvolting-PowerEdition,18013.html
    this issue on some mb with one of these cards is a no post issue. if the card under 30 days i would return it and try anther brand. or see if your card has that chip.
  2. I tested the GPU in another PC and there it works fine. How do you check if the card has that chip?
    Tomorrow I'll return the card and buy another one. I hope the issue will be solved.
    Is there anything else that could be the problem?
    I'm going to order this GPU: ASUS GeForce GTX 660 DirectCU II
    are there also POST issues with this one?
    thx for the reply
Graphics Cards GPUs Hewlett Packard Graphics
