Solved
First Gaming Build Help
Last response: in Systems
Okay so I'm getting ready to build my first PC (keep in mind I will be coming from a dedicated graphics card on a 2009 iMac to this) and I would like some input on which combination of cpu/gpu will provide me with the best fps/playability with good settings at 1920 x 1024:
I3-3220 and radeon 7850
Or
I5-3450 and radeon 7770
I'm thinking that an i5 would be better to start off with because I could upgrade the graphics card in a year or so.
(I plan on playing sc2, gw2, d3, wow, skyrim, maybe some bf3)
More about : gaming build
Best solution
Graphics card Expert
for 1080p, definitely 7850.
You might consider the AMD FX-6300 over the i3. It's got 6 slower cores compared to the 2 fast ones in the i3. It does as well at gaming as the i3, but the 6 cores really help for other tasks like video editing, etc. Only downside is it uses an extra 35W of power.
