Sign-in / Sign-up
New Graphics Card and 1600 x 900 Resolution Help!
  • Graphics Cards
  • Resolution
  • Support
  • Monitors
  • Graphics
Last response: in Displays
October 9, 2012 12:02:55 AM
hello!
I have a 1600 x 900 native resolution HP flat screen monitor, and I want to buy a new graphics
card to use with it. Most card info on Mfg. web sites do not tell what screen resolutions their
cards support; only the maximum resolution.
In choosing a new card, does that card have to specifically support a 1600 x 900 screen resolution
to work with my monitor, or will any current card with a maximum resolution capability greater than
my monitor be able support the 1600 x 900 resolution?
Does the windows operating system ( XP or beyond ) influence the resolution choices available, or
is this all in the particular card driver software? If the card must specifically support the 1600 x 900
resolution, how can I determine if the card supports this?
Many Thanks!
Dan
More about : graphics card 1600 900 resolution
October 9, 2012 12:11:44 AM
Any modern video card will support 1600x900, so it doesn't really matter which one you buy.
m
l
October 9, 2012 12:27:13 AM
I did find at least 1 current card where the Mfg. specs listed the supported resolutions,
and 1600 x 900 was not on the list. What does this mean?
m
l
October 9, 2012 12:28:19 AM
m
l
