Sapphire HD 7850 2GB OC Power Consumption
Will a 500w or 550w PSU work for this work even though it says minimum 500w? How much power will it use and will 500w also be enough to run my other components?
GPU: Sapphire Radeon HD 7850 2GB OC
PSU: Antec BP550 550W
Other PSU Choice: Corsair Builders Series CX500 V2
Other Computer Components in my Build.
CPU: AMD FX-4170 4.2 Ghz
Motherboard: GIGABYTE GA-990FXA-UD3
RAM: Kingston HyperX 8GB DDR3 1600
HDD: Wester Digital 320gb Caviar Blue
CD/DVD Burner: LITE-ON DVD Burner
Aftermarket CPU Cooler: Cooler Master Hyper 212 Evo
Case: Rosewill Challenger U3
GPU: On Top
PSU: On Top
My Budget is nothing over $780 the lower the better
GPU: On Top
PSU: On Top
More about : sapphire 7850 2gb power consumption
Such recommendations are for people who don't know how to read numbers and do simple math or don't want to do it. These recommendations don't matter and the wattage of a PSU doesn't matter.
What matters is +12V amperage because this is the power used by CPUs and graphics cards as well as some other components such as hard drives and most fans. Some 350W PSUs can handle a 7850 with a low power CPU suc has an Ivy Bridge i3 or an AMD Trinity quad-core APU with its IGP disabled, some 600W PSUs can't. You have to check the +12V amperage of a PSU and find the +12V consumption of your computer to find out if a PSU is good enough.
Related ressources
- Power Supply for i7 3770K & Sapphire HD 7850 2GB OC - Forum
- Sapphire radeon 7850 oc power requirements - Forum
- Strange Noises with Sapphire HD 7850 OC 2GB GDDR5 - Forum
- Power Supply for Sapphire HD 7850 2GB OC Edition - Forum
- SAPPHIRE HD 7850 OC 2GB GDDR5 or MSI N560GTX-Ti Twin Frozr II 2GD5/ OC - Forum
luciferano said:
Such recommendations are for people who don't know how to read numbers and do simple math or don't want to do it. These recommendations don't matter and the wattage of a PSU doesn't matter.What matters is +12V amperage because this is the power used by CPUs and graphics cards as well as some other components such as hard drives and most fans. Some 350W PSUs can handle a 7850 with a low power CPU suc has an Ivy Bridge i3 or an AMD Trinity quad-core APU with its IGP disabled, some 600W PSUs can't. You have to check the +12V amperage of a PSU and find the +12V consumption of your computer to find out if a PSU is good enough.
out of the 2 PSU which do you think is the better choice?
examplehi said:
out of the 2 PSU which do you think is the better choice?Out of the two and also the Rosewill model suggested by dudewitbow, I'd recommend that Corsair CX500 V2 model. The Antec has an annoying triple rail setup that is overkill anyway and the Rosewill is also way overkill. I don't like them as a brand much for PSUs either (although I do like numerous Rosewill cases very much), but I admit that that is more subjective.
<<Is sensing someone doesn't know the value in the superflower designed Capstone unit
i mean its like 65$ in the combo technically, so its actually alot more affordable. Unless you are going through with the possible MIR(as corsair is slow to the gun on those) Capstone holds one of the highest price to performance ratios
dudewitbow said:
<<Is sensing someone doesn't know the value in the superflower designed Capstone uniti mean its like 65$ in the combo technically, so its actually alot more affordable. Unless you are going through with the possible MIR(as corsair is slow to the gun on those) Capstone holds one of the highest price to performance ratios
The problem is that it is far overkill on the +12V rails. You could literally halve it and still be plenty. Way overkill PSUs can be a detriment to a system. I might consider that PSU for a Radeon 7870 Crossfire build, but not for a build with with a 7850, not even with such a fairly high-power CPU as the FX-4170.
EDIT: Also, the Corsair unit is still cheaper.
luciferano said:
The problem is that it is far overkill on the +12V rails. You could literally halve it and still be plenty. Way overkill PSUs can be a detriment to a system. I might consider that PSU for a Radeon 7870 Crossfire build, but not for a build with with a 7850, not even with such a fairly high-power CPU as the FX-4170.EDIT: Also, the Corsair unit is still cheaper.
cheaper by like 3$(13 if you get the rebate(corsair unit has shipping cost)). part of the price also is reflected vs the warranty periods(3 vs 5 years)
dudewitbow said:
Also:http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
if you want a great psu
if you're willing to pay a bit more for a 7870
would also recommend at least paying 5$ more for the extra gb
why is that PSU Discontinued?
dudewitbow said:
cheaper by like 3$(13 if you get the rebate(corsair unit has shipping cost)). part of the price also is reflected vs the warranty periods(3 vs 5 years)You're far more likely to need that warranty with that Rosewill than with the Corsair. Like I said earlier, I think that I could make a better recommendation than any of these.
http://pcpartpicker.com/part/corsair-power-supply-cmpsu...
$25 is about as cheap as it can get and still get such a PSU as this. The Rosewill doesn't come close in value for OP's situation.
Those two are my recommendations if OP wants a five-year warranty.
I haven't checked yet, but I'll see if a favorable Rosewill model is also available here without a way overkill +12V rail configuration.
luciferano said:
You're far more likely to need that warranty with that Rosewill than with the Corsair. Like I said earlier, I think that I could make a better recommendation than any of these.http://pcpartpicker.com/part/corsair-power-supply-cmpsu...
I would disagree, the cx unit is far more likely to crash before the capstone unit. albeit old, theres a reason why communities listed the capstone unit a tier higher than the cx unit
for further comparison the capstone performs similar to the corsair tx750m but at a higher efficiency rating, lower cost.
dudewitbow said:
I would disagree, the cx unit is far more likely to crash before the capstone unit. albeit old, theres a reason why communities listed the capstone unit a tier higher than the cx unitCapstone is arguably more reliable, but when you severely underload a PSU, it is less reliable. It's a higher quality model than the Corsair CX series, but it is not oriented towards OP's power usage. The 450W Capstone would be better for OP, but it's also still overkill.
luciferano said:
Capstone is arguably more reliable, but when you severely underload a PSU, it is less reliable. It's a higher quality model than the Corsair CX series, but it is not oriented towards OP's power usage. The 450W Capstone would be better for OP, but it's also still overkill.its only such way unless the psu is under less than 20% load. once its past 20% then the efficiency should work as planned. no matter what psu you would use, if a computer is on idle, it technically is at its most inefficient state.
I would not think it would underload itself. I mean its similar to people who have SLI/Crossfire builds. When you are not gaming, you turn off sli/crossfire, so where would the rest of the power go. its being unused for a period of time, but the gap in that situation would be significantly bigger gap then a single card build with a slightly larger psu. OP has an FX-4170 with an aftermarket cooler with a tdp of 125w(note that amd builds have a higher power consumption), Most likely with the intention to overclock as well as a 7850, which may as well be overclocked too. the load of the two parts alone should at least strain more than half of the Capstone unit when under load. bringing the build down to a 408w(cx 500w level) is pretty close to the cap alone.
luciferano said:
Capstone is arguably more reliable, but when you severely underload a PSU, it is less reliable. It's a higher quality model than the Corsair CX series, but it is not oriented towards OP's power usage. The 450W Capstone would be better for OP, but it's also still overkill.what does OP stand for?
I think that the BP550 Plus is fine,aside from having great reviews,it also has 3x12V rails that sum up to 69 Amps,69 amps has the potential to output 828 watts on the 12V rails alone,whether or not this is possible remains to be seen with the other components the psu is built with but from the amps it seems great.
also anandtech tested the 7850 for it's max power consumption and it,along with the rest of the system drew only 385 watts.so even disregarding that this power supply has the potential to output more than it's rated amount,the psu should be fine.
I'd recommend switching to the samsung f3,it is a great quality hdd.
I'd also recommend switching to a phenom x6.
http://www.cpu-world.com/Compare/320/AMD_FX-Series_FX-4...
check the performance tab on there it compares the phenom x6 to the fx 4100,and the phenom wins almost every time.
and the cost is almost the same
http://www.amazon.com/AMD-Phenom-1045T-2-70GHz-Processo...
mvitkun said:
I think that the BP550 Plus is fine,aside from having great reviews,it also has 3x12V rails that sum up to 69 Amps,69 amps has the potential to output 828 watts on the 12V rails alone,whether or not this is possible remains to be seen with the other components the psu is built with but from the amps it seems great.also anandtech tested the 7850 for it's max power consumption and it,along with the rest of the system drew only 385 watts.so even disregarding that this power supply has the potential to output more than it's rated amount,the psu should be fine.
multiple rails aren't additive. Antec has the OCP set to 36 amps on the unit. it cannot go past that mark much.
dudewitbow said:
I would not think it would underload itself. I mean its similar to people who have SLI/Crossfire builds. When you are not gaming, you turn off sli/crossfire, so where would the rest of the power go. its being unused for a period of time, but the gap in that situation would be significantly bigger gap then a single card build with a slightly larger psu. OP has an FX-4170 with an aftermarket cooler with a tdp of 125w(note that amd builds have a higher power consumption), Most likely with the intention to overclock as well as a 7850, which may as well be overclocked too. the load of the two parts alone should at least strain more than half of the Capstone unit when under load. bringing the build down to a 408w(cx 500w level) is pretty close to the cap alone.Wattage is almost irrelevant, what matters is +12V amperage. The way that PSUs are rated for wattage also varies from model to model, especially with different brands. Besides that, in gaming, a stock 7850 uses under 130W and even overclocked and overvolted, it rarely breaks 150-160W. The FX-4170 is unlikely to go far past 120-130W. Altogether, OP's build would probably be more like 225-275W on the +12V at stock in gaming and around 250-315W overclocked in gaming from the graphics and CPU. The rest of the system won't load up another 108W or so and the closest that it would get to that would be start-up and stress testing.
At stock, even the CX 430 could handle this system, although I think that that would be pushing it at this point and I'll retract that recommendation. I still recommend my other suggestions.
The FX-4170 beats the Phenom II x6 1100T, the best Phenom II x6 in gaming performance. The 4100 doesn't come close. In gaming, the Phenom II x6 1045T would be crushed and even the FX-4100 would beat it. Don't make gaming recommendations based on non-gaming benchmarks.
Samsung's HDDs aren't great since they sold out to Seagate. Western Digital Caviar Blue is currently better.
Related ressources:
- ForumMSI R 7850 Power Edition 2GD5/ OC Wattage Consumption
- Forum560 Ti DS Superclocked (1GB) vs 7850 OC ( 2GB )
- ForumI5-3570 and HD7850 2GB or i5-3350p and HD7850 1GB
- ForumMSI Twin Frozr III R 7850 OC POWER EDITION OR SAPPHIRE HD 7850
- ForumIs the Sapphire HD7850 2GB worth the money for a single monitor setup?
- ForumSapphire HD 7850 2gb OC Dual X Version
- ForumSapphire 7850 2gb +psu overclock trixx?
- ForumSapphire Radeon 2GB 7850 - lacking performance??
- ForumSapphire Radeon HD 7850 oc 2gb vs MSI R 7850 Twin Frozr?
- ForumSapphire Radeon HD7850 OC vs Asus HD7850 DC2 2GD5
- ForumHD 7850 OC " Sapphire " or "Gigabyte" !
- Forum[ Sapphire Radeon HD 7850 OC ] or [MSI N560GTX-Ti Hawk]
- ForumSapphire Radeon HD7850 2GB DDR5 OC or Axle Geforce GTX 660 2GB DDR5?
- ForumEvga gtx 570 hd superclocked vs sapphire HD 7850 OC 2GB
- ForumHD 7870
- More resources
