Can Your Find a Problem With My PC Build?
Last response: in Systems
November 30, 2012 9:04:29 PM
Dear Internet,
I've put together my PC build and I wanted to see if anyone could find a problem with it.
The Specs are...
i3 2125 CPU
AMD Radeon HD 7770
4GB 1333Mhz Ram (Generic Ram, I don't care about it that much, 2 sticks)
GA-H61M-DS2H Mobo
Antec BP500U PSU
SH-244BB DVD Drive
200 GB Sata Hard Drive (Pulled from an old HP Media Center m7060n)
Antec Three Hundred Case
Also, please don't say that what's wrong with it is something like "AMD Sucks, Buy NVIDIA!!1!!1"
Thanks
More about : find problem build
a b B Homebuilt system
November 30, 2012 10:09:48 PM
well, 200 isn't that much storage so you might want to consider more. Also, how old is your hp, wannt make sure it will be compatible
m
l
December 1, 2012 12:24:39 AM
The HP is from around 2006
HP's Website Says...
200 GB SATA
7200 rpm
I was more concerned about the PSU, if someone could look into that.
m
l
December 1, 2012 12:47:02 AM
Any sata will run with any other vresion of sata.
500w is more then enough for that build.
Hm.. Does it make a noise when it starts up?
m
l
December 1, 2012 1:10:59 AM
I don't have the build yet, I just wanted to know if everything checked out before I bought it. I'm not really worried about wattage but more about amperage. The PSU has 2 12V rails rated at 18A. I'm concerned as to weather those mix or not, or if 18A is enough to power my GPU and everything else.
Also the Radeon HD 7770 is the XFX Double D factory overclocked at 1095MHz
m
l
