Solved
New build computer powers on, beeps, but no display. Please help...
  • New Build
  • Computer
  • New Build
  • Systems
  • Product
  • Displays
Last response: in Systems
December 1, 2012 2:52:16 AM
I finally put my whole new build together. The computer powers on and beeps but nothing shows on the screen. The mobo also came with a disk and I have yet to install it along with my windows 7 oem. I've never done a build before so I'm clueless what to do from here.
More about : build computer powers beeps display
December 1, 2012 3:05:34 AM
What are your components?
m
l
December 1, 2012 3:08:15 AM
My base components are:
-GIGABYTE GA-B75M-D3V LGA 1155 Intel B75 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
-7850 2gb gpu
-A560 Cougar psu
-4x2 ram
-2120 cpu
m
l
December 1, 2012 3:16:29 AM
Yup. Went through that list and I've done every step.
m
l
December 1, 2012 3:32:44 AM
What kind of ram do you have? You tried connecting the monitor to the video card and taking the video card out then connecting the monitor to the mobo?
m
l
December 1, 2012 3:48:21 AM
Power down then connect the monitor to the video card and try that.
m
l
December 1, 2012 3:50:46 AM
I don't have that blue port on my video card though.
m
l
Best solution
December 1, 2012 3:57:50 AM
Your video card or monitor didn't come with one of these vga to dvi http://www.amazon.com/StarTech-DVI-Cable-Adapter-DVIVGA...
If it didn't just take your video card out and connect the monitor to the mobo.
December 1, 2012 3:58:02 AM
That might be the issue. Let me have a look around my house and see if I can find something that'll hook up to video card...
m
l
December 1, 2012 4:10:45 AM
I just looked in the box... and I found that vga to dvi :D . You have honestly made me so happy because my computer is working!!! Thanks a bunch. One more question ould you happen to know how I can get windows 7 oem on my computer w/ out a dvd drive?
m
l
December 1, 2012 4:28:33 AM
That's good to hear :)  You can't use the one from the computer you're using now. If it's a laptop or someone doesn't want you taking their pc apart you could buy one cheap $16 http://www.newegg.com/Product/Product.aspx?Item=N82E168...
m
l
December 1, 2012 1:24:35 PM
Best answer selected by TrueTexan.
m
l
