Gpu upgrade help!
hello all
i have a pc that i whant to upgrade gpu to the maximum my pc can take
i will type as much possible my pc specs so u can have a better idea
psu>
general
type ATX12V V2.2 power 450 W
Τech
DC Output +3,3V--22A
DC Output +5V-----15A
DC Output +12V1---14 A
DC Output +12V2---16 A
Efficiency 65%
PFC passive
Main connector (20+4 Pin)1xPCI-E (6+2 Pin) SATA 5 Floppy (Y-cable)
motherboard :asus p5kpl-vm
cpu intel quad:6600
2 gig ram 667
monitor resolution 1440x900
thats my specs, old card was asus 8600gt, still works but i cant play any new game smooth what is the maximum gpu this pc can take? lf opinons:)
ps: sorry for my bad english..
More about : gpu upgrade
i would just say to save up some money and build a brand new system because you have very old psu,cpu,motherboard,ram,gpu and i don't even know about the power supply i have never heard of a general power supply where did you buy this from? or did you build it
Related ressources
Kamen_BG said:
Ugh actually i have to correct myself now... The GTX 650 Ti came out a day ago and it's probably the fastest card your PSU can run without any problems
thnx for the answers! so u suggest that i can go with gtx 650 and i will be fine? and if yes what brand u propose?
Ask the community
