Tom's Hardware > Forum > Windows XP > Device Driver > HELP!!! system crash in USB multi stage Bulk out using IOC..
Forum Windows XP : Device Driver - HELP!!! system crash in USB multi stage Bulk out using IOC..
Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
Hello all,
I am using my driver sample from Win2k DDK isousb sample driver , and
wanted to add support in it
for Bulk OUT . So i added an IOCTL for Bulk Transfer . This also
worked fine , however for a limited buffer
size . So i decided to add mutli-staging to it( IRP reuse ) , and for
that basically used the sample code in Bulkusb.sys XP DDK sample .
BulkUsb.sys was handling Bulk write requests through IRP_MJ_WRITE
dispatch routine , but i am doint it through
IOCTLs.
This however crashes my system , and i am at a loss to understand why.
When i single step through the completion routine in the Kernel
debugger , by setting a breakpoint
in the completion routine , and when it hits the breakpoint second
time , sometimes single steppign thru the code
and taking function call stack trace , a call to NT!IoCancelIRP is
showing up , looks like somebody is canceling the
IRP
At other times when not single stepping but with KD attached , it
breaks with a second chance AV in the
IoBuildPartialMdl() function call in completion routine
If KD is not attached , the system crashes and the bugcheck code is
something like MULTIPLE_COMPLETION_ROUTINES ( i fogot
the exact code but u get the idea )
Some of the code snippets from IOctlDispatcher , Bulk_Write_Handler
and CompletionRoutine are as follows:
The EXACT source ( lengthy ) to these functions is also at the very
end of the message .
I would very much appreciate any help
thanks in advance
Taha
IN DEVIOCTL DISPATCH ROUTINE
case BULK_WRITE:
ntStatus = Bulk_Write_Multiple_Stage(FdoDeviceObject , Irp);
break;
Irp->IoStatus.Status = ntStatus;
IoCompleteRequest (Irp,
IO_NO_INCREMENT
return ntStatus;
IN BULK_WRITE_MULTIPLE_STAGE
if(totalLength > MAX_BULK_TRANSFER_SIZE)
stageLength = MAX_BULK_TRANSFER_SIZE;
else
stageLength = totalLength;
mdl = IoAllocateMdl((PVOID) virtualAddress,
totalLength,
FALSE,
FALSE,
NULL);
// map the portion of user-buffer described by an mdl to another
mdl
IoBuildPartialMdl(Irp->MdlAddress,
mdl,
stageLength);
urb = ExAllocatePool(NonPagedPool,
sizeof(struct
_URB_BULK_OR_INTERRUPT_TRANSFER));
UsbBuildInterruptOrBulkTransferRequest(
urb,
sizeof(struct
_URB_BULK_OR_INTERRUPT_TRANSFER),
bulkPipeInfo->PipeHandle,
NULL,
mdl,
stageLength,
urbFlags,
NULL);
// set BULKUSB_RW_CONTEXT parameters.
rwContext->Urb = urb;
rwContext->Mdl = mdl;
rwContext->Length = totalLength - stageLength;
rwContext->Numxfer = 0;
rwContext->VirtualAddress = virtualAddress + stageLength;
rwContext->DeviceExtension = deviceExtension;
// use the original read/write irp as an internal device control
irp
nextStack = IoGetNextIrpStackLocation(Irp);
nextStack->MajorFunction = IRP_MJ_INTERNAL_DEVICE_CONTROL;
nextStack->Parameters.Others.Argument1 = (PVOID) urb;
nextStack->Parameters.DeviceIoControl.IoControlCode =
IOCTL_INTERNAL_USB_SUBMIT_URB;
IoSetCompletionRoutine(Irp,
(PIO_COMPLETION_ROUTINE)ReadWriteCompletion,
rwContext,
TRUE,
TRUE,
TRUE);
IoMarkIrpPending(Irp);
ntStatus = IoCallDriver(deviceExtension->TopOfStackDeviceObject,
Irp);
return STATUS_PENDING;
IN CASE OF ERRORS , we jump to a label which has the following (
completes IRP )
Irp->IoStatus.Information = 0;
IoCompleteRequest(Irp, IO_NO_INCREMENT);
return ntStatus;
IN THE COMPLETION ROUTINE
ntStatus = Irp->IoStatus.Status;
( PSEUDOCODE ) ...if ntStatus == Success , then handle chunk , and
return STATUS_MORE_PROCESSING_REQUIRED;
else for last chunk keep going and return whatever ntStatus has
EXACT SOURCE
#define IOCTL_USBXGA_BULK_WRITE CTL_CODE(FILE_DEVICE_UNKNOWN, \
USBXGA_IOCTL_INDEX+9,\
METHOD_IN_DIRECT,
FILE_ANY_ACCESS)
typedef struct _BULKUSB_RW_CONTEXT {
PURB Urb;
PMDL Mdl;
ULONG Length; // remaining to xfer
ULONG Numxfer; // cumulate xfer
ULONG_PTR VirtualAddress; // va for next segment of xfer.
PDEVICE_EXTENSION DeviceExtension;
} BULKUSB_RW_CONTEXT, * PBULKUSB_RW_CONTEXT;
NTSTATUS USBXGA_ProcessIOCTL(IN PDEVICE_OBJECT FdoDeviceObject, IN
PIRP Irp)
PIO_STACK_LOCATION irpStack;
PVOID ioBuffer;
ULONG inputBufferLength;
ULONG outputBufferLength;
PDEVICE_EXTENSION deviceExtension;
ULONG ioControlCode;
NTSTATUS ntStatus;
UCHAR RefreshRate, Resolution;
USBXGA_KdPrint( DBGLVL_DEFAULT,("USBXGA_ProcessIOCTL...Start\n" ));
USBXGA_KdPrint( DBGLVL_DEFAULT,("IRP_MJ_DEVICE_CONTROL\n" ));
USBXGA_IncrementIoCount(FdoDeviceObject);
// Get a pointer to the current location in the Irp. This is where
// the function codes and parameters are located.
deviceExtension = FdoDeviceObject->DeviceExtension;
// Can't accept a new io request if:
// 1) device is removed,
// 2) has never been started,
// 3) is stopped,
// 4) has a remove request pending,
// 5) has a stop device pending
if ( !USBXGA_CanAcceptIoRequests( FdoDeviceObject ) )
USBXGA_KdPrint( DBGLVL_DEFAULT,("USBXGA_ProcessIOCTL...USBXGA_CanAcceptIoRequests
Fail\n" ));
ntStatus = STATUS_DELETE_PENDING;
IoCompleteRequest( Irp, IO_NO_INCREMENT );
USBXGA_DecrementIoCount(FdoDeviceObject);
return ntStatus;
irpStack = IoGetCurrentIrpStackLocation (Irp);
Irp->IoStatus.Status = STATUS_SUCCESS;
// get pointers and lengths of the caller's (user's) IO buffer
ioBuffer = Irp->AssociatedIrp.SystemBuffer;
inputBufferLength =
irpStack->Parameters.DeviceIoControl.InputBufferLength;
outputBufferLength =
irpStack->Parameters.DeviceIoControl.OutputBufferLength;
ioControlCode = irpStack->Parameters.DeviceIoControl.IoControlCode;
USBXGA_KdPrint( DBGLVL_DEFAULT,("USBXGA_ProcessIOCTL...ioControlCode=%x\n",ioControlCode));
switch (ioControlCode)
case IOCTL_USBXGA_BULK_WRITE:
USBXGA_KdPrint( DBGLVL_DEFAULT,("USBXGA_ProcessIOCTL...IOCTL_USBXGA_BULK_WRITE\n" ));
ntStatus = USBXGA_Bulk_Write_Multiple_Stage(FdoDeviceObject , Irp);
break;
default:
USBXGA_KdPrint( DBGLVL_DEFAULT,("USBXGA_ProcessIOCTL...Unhandled\n" ));
ntStatus =
Irp->IoStatus.Status = STATUS_INVALID_PARAMETER;
IO_NO_INCREMENT
USBXGA_KdPrint( DBGLVL_DEFAULT,("USBXGA_ProcessIOCTL...End\n" ));
return ntStatus;
NTSTATUS
IN PDEVICE_OBJECT fdo,
IN PIRP Irp
Routine Description:
Arguments:
Return Value:
NT status code
STATUS_SUCCESS: Read was done successfully
PMDL mdl = NULL;
PURB urb = NULL;
ULONG totalLength;
ULONG stageLength;
ULONG urbFlags;
BOOLEAN read;
NTSTATUS ntStatus;
ULONG_PTR virtualAddress;
PFILE_OBJECT fileObject = NULL;
PDEVICE_EXTENSION deviceExtension= NULL;
PIO_STACK_LOCATION irpStack = NULL;
PIO_STACK_LOCATION nextStack = NULL;
PBULKUSB_RW_CONTEXT rwContext = NULL;
PUSBD_PIPE_INFORMATION bulkPipeInfo = NULL;
PUSBD_INTERFACE_INFORMATION interfaceInfo = NULL;
BOOLEAN bFoundBulkPipe = FALSE;
UINT32 nCurrPipe;
// initialize variables
urb = NULL;
mdl = NULL;
rwContext = NULL;
totalLength = 0;
irpStack = IoGetCurrentIrpStackLocation(Irp);
fileObject = irpStack->FileObject;
read = (irpStack->MajorFunction == IRP_MJ_READ) ? TRUE : FALSE;
deviceExtension = (PDEVICE_EXTENSION) fdo->DeviceExtension;
USBXGA_KdPrint( DBGLVL_DEFAULT,("\n
USBXGA_Bulk_Write_Multiple_Stage() Begins..\n" ));
if(TRUE != deviceExtension->DeviceStarted )
USBXGA_Bulk_Write_Multiple_Stage() ...ERROR!Invalid device state ...
Exiting \n" ));
ntStatus = STATUS_INVALID_DEVICE_STATE;
goto BulkUsb_DispatchReadWrite_Exit;
interfaceInfo = deviceExtension->UsbInterface;
if (!interfaceInfo)
USBXGA_Bulk_Write_Multiple_Stage() ERROR! no interface info -
Exiting" ));
ntStatus = STATUS_UNSUCCESSFUL;
for ( nCurrPipe=0 ; nCurrPipe < interfaceInfo->NumberOfPipes ;
nCurrPipe++)
if ( UsbdPipeTypeBulk == interfaceInfo->Pipes[nCurrPipe].PipeType )
bFoundBulkPipe = TRUE;
break;
if ( FALSE == bFoundBulkPipe )
USBXGA_Bulk_Write_Multiple_Stage() ERROR! , did not find a Bulk Pipe
in the interface - Exiting" ));
ntStatus = STATUS_INVALID_PARAMETER;
bulkPipeInfo = &(interfaceInfo->Pipes[nCurrPipe] );
rwContext = (PBULKUSB_RW_CONTEXT)
sizeof(BULKUSB_RW_CONTEXT));
if(NULL == rwContext )
USBXGA_Bulk_Write_Multiple_Stage() ...ERROR! Failed to alloc mem for
rwContext.. Exiting \n" ));
ntStatus = STATUS_INSUFFICIENT_RESOURCES;
if(Irp->MdlAddress)
totalLength = MmGetMdlByteCount(Irp->MdlAddress);
else
//just log to the debugger that we got a NULL MDL Address
USBXGA_Bulk_Write_Multiple_Stage() ... Info Only : Irp->MdlAddress is
NULL \n" ));
if(totalLength > USBXGA_ARBITRARY_MAX_BULK_BUFFER_SIZE )
USBXGA_Bulk_Write_Multiple_Stage() ...ERROR! total buffer length is
GREATER than Arbitrary total size.. Exiting \n" ));
ExFreePool(rwContext);
if(totalLength == 0)
USBXGA_Bulk_Write_Multiple_Stage() ... Info Only : Transfer data
length = 0\n" ));
ntStatus = STATUS_SUCCESS;
urbFlags = USBD_SHORT_TRANSFER_OK;
virtualAddress = (ULONG_PTR)
MmGetMdlVirtualAddress(Irp->MdlAddress);
if(read)
urbFlags |= USBD_TRANSFER_DIRECTION_IN;
USBXGA_Bulk_Write_Multiple_Stage() ... Info Only : Read operation on
Bulk pipe \n" ));
else
urbFlags |= USBD_TRANSFER_DIRECTION_OUT;
USBXGA_Bulk_Write_Multiple_Stage() ... Info Only : Write operation on
Bulk pipe \n" ));
// the transfer request is for totalLength.
// we can perform a max of ISO_MAX_BULK_TRANSFER_SIZE
// in each stage.
if(totalLength > ISO_MAX_BULK_TRANSFER_SIZE)
stageLength = ISO_MAX_BULK_TRANSFER_SIZE;
USBXGA_Bulk_Write_Multiple_Stage() ... Info Only : stageLength =
ISO_MAX_BULK_TRANSFER_SIZE \n" ));
else
totalLength \n" ));
totalLength,
FALSE,
FALSE,
NULL);
if(NULL == mdl )
USBXGA_Bulk_Write_Multiple_Stage() ... ERROR! Failed to alloc mem for
mdl .. Exiting \n" ));
mdl
mdl,
stageLength);
sizeof(struct
if(NULL == urb )
urb.. Exiting \n" ));
IoFreeMdl(mdl);
urb,
sizeof(struct
NULL,
mdl,
stageLength,
urbFlags,
NULL);
irp
(PIO_COMPLETION_ROUTINE)USBXGA_BulkUsb_ReadWriteCompletion,
rwContext,
TRUE,
TRUE,
TRUE);
// since we return STATUS_PENDING call IoMarkIrpPending.
// This is the boiler plate code.
// This may cause extra overhead of an APC for the Irp completion
// but this is the correct thing to do.
USBXGA_IncrementIoCount(fdo);
USBXGA_Bulk_Write_Multiple_Stage() ... Info only: About to Call
IoCallDriver \n" ));
Irp);
if(!NT_SUCCESS(ntStatus))
USBXGA_KdPrint( DBGLVL_DEFAULT,("\n IoCallDriver fails with status
%X\n", ntStatus));
// if the device was yanked out, then the pipeInformation
// field is invalid.
// similarly if the request was cancelled, then we need not
// invoked reset pipe/device.
if( (ntStatus != STATUS_CANCELLED) &&
(ntStatus != STATUS_DEVICE_NOT_CONNECTED)
ntStatus = USBXGA_ResetPipe(fdo, bulkPipeInfo);
USBXGA_Bulk_Write_Multiple_Stage() ... ERROR! USBXGA_ResetPipe failed
with ntstatus == %x , Attempting to Reset Device\n" , ntStatus));
else
USBXGA_Bulk_Write_Multiple_Stage() ... ntStatus is STATUS_CANCELLED or
STATUS_DEVICE_NOT_CONNECTED\n" ));
// we return STATUS_PENDING and not the status returned by the
lower layer.
BulkUsb_DispatchReadWrite_Exit:
USBXGA_KdPrint( DBGLVL_DEFAULT,("\n BulkUsb_DispatchReadWrite -
ends\n" ));
return ntStatus;
NTSTATUS
USBXGA_BulkUsb_ReadWriteCompletion(
IN PDEVICE_OBJECT DeviceObject,
IN PIRP Irp,
IN PVOID Context
ULONG stageLength;
NTSTATUS ntStatus;
PIO_STACK_LOCATION nextStack;
PBULKUSB_RW_CONTEXT rwContext;
rwContext = (PBULKUSB_RW_CONTEXT) Context;
UNREFERENCED_PARAMETER(DeviceObject);
USBXGA_BulkUsb_ReadWriteCompletion() Begins..\n" ));
// successfully performed a stageLength of transfer.
// check if we need to recirculate the irp.
if(NT_SUCCESS(ntStatus)) {
if(rwContext) {
rwContext->Numxfer +=
rwContext->Urb->UrbBulkOrInterruptTransfer.TransferBufferLength;
if(rwContext->Length) {
// another stage transfer
USBXGA_BulkUsb_ReadWriteCompletion() ...Another stage transfer...
...\n" ));
if(rwContext->Length > ISO_MAX_BULK_TRANSFER_SIZE) {
else {
stageLength = rwContext->Length;
rwContext->Mdl,
(PVOID) rwContext->VirtualAddress,
stageLength);
// reinitialize the urb
stageLength;
rwContext->VirtualAddress += stageLength;
rwContext->Length -= stageLength;
rwContext->Urb;
rwContext,
TRUE,
TRUE,
TRUE);
IoCallDriver(rwContext->DeviceExtension->TopOfStackDeviceObject,
Irp);
else {
// this is the last transfer
Irp->IoStatus.Information = rwContext->Numxfer;
else
USBXGA_BulkUsb_ReadWriteCompletion - failed with ntStatus = %X\n",
ntStatus));
if(rwContext)
// dump rwContext
USBXGA_KdPrint(DBGLVL_DEFAULT,
("USBXGA_BulkUsb_ReadWriteCompletion() - rwContext->Urb =
%X\n",
rwContext->Urb));
("USBXGA_BulkUsb_ReadWriteCompletion() - rwContext->Mdl =
%X\n",
rwContext->Mdl));
("USBXGA_BulkUsb_ReadWriteCompletion() - rwContext->Length =
%d\n",
rwContext->Length));
("USBXGA_BulkUsb_ReadWriteCompletion() - rwContext->Numxfer =
%d\n",
rwContext->Numxfer));
("USBXGA_BulkUsb_ReadWriteCompletion() - rwContext->VirtualAddress =
%X\n",
rwContext->VirtualAddress));
("USBXGA_BulkUsb_ReadWriteCompletion() - rwContext->DeviceExtension =
%X\n",
rwContext->DeviceExtension));
BulkUsb_ReadWriteCompletion::" ));
USBXGA_DecrementIoCount(DeviceObject);
ExFreePool(rwContext->Urb);
IoFreeMdl(rwContext->Mdl);
("USBXGA_BulkUsb_ReadWriteCompletion() - ends\n" ));
return ntStatus;
Sponsored Links
There are 732 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
