Solved
First Homebuilt Computer Help
Last response: in Systems
December 3, 2012 4:58:18 AM
I've been doing some research and this seems to be the cost effective way to get a gaming computer i have around $450-$650 and would like to play games like dark souls/borderlands 2 on average setting if i can get the parts a local store that would be better any help would be appreciated
More about : homebuilt computer
a c 106 B Homebuilt system
December 3, 2012 5:00:07 AM
So....
Do you have a question?
m
l
December 3, 2012 5:09:50 AM
ah yes sorry what would be the best components for the budget
m
l
December 3, 2012 5:47:20 AM
Approximate Purchase Date: Before Christmas
Budget Range:$450-$650 After Rebates/After Shipping
System Usage from Most to Least Important: Gaming
Are you buying a monitor: No
Parts to Upgrade: None building from scratch
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg.com/Bestbuy.com/Fryselectronics.com
Parts Preferences: None
Overclocking: Maybe
SLI or Crossfire: Yes
Your Monitor Resolution:1920x1080
Additional Comments: Dark Souls/Borderlands 2/DotA 2 other such newer games
And Most Importantly, Why Are You Upgrading: Current computer running games at low settings and having trouble doing so would like to run atleast average settings
m
l
Best solution
December 3, 2012 6:24:43 AM
CPU: Core i3-3220. $120
Mobo: AsRock H77 Pro4. $80
RAM: G.Skill Ares 8GB (2x4GB) 1600Mhz CL9 1.5v. $38
GPU: Sapphire Vapor-X HD7770. $120 ($15 rebate)
PSU: XFX Core 550W, 80+ Bronze. $70 ($10 rebate)
HDD: Seagate Barracuda 1TB 7200RPM. $70
Case: Zalman Z9+. $60
Total (before rebates and shipping): $558
You have a fair bit of cash left, around $100. Where you want to put the cash is up to you. Good options I can see is a better case, an SSD, a CPU/mobo upgrade or a better GPU.
If your after longevity over a long time frame, then I advise the case upgrade, as that will last longer than any of the stuff inside it.
If your after longevity over a medium timeframe, then I advise the CPU mobo upgrade. Get a 3570k and a Z77 board. That means the rig is easily upgradable (can just throw any new GPU you want in without fear of bottlenecking).
If your after performance right now, upgrade the GPU to a 7850/660.
If your after blazing boot up times and general responsiveness in the rig, then get an SSD.
December 3, 2012 6:55:34 AM
thanks manofchalk one more quick question being a homebuilt it would be relatively easy to upgrade any of the components down the road correct?
m
l
December 3, 2012 6:55:48 AM
Best answer selected by Oukranos.
m
l
December 3, 2012 7:04:47 AM
Yep, thats whats good about custom machines, its relatively easy to replace components in the rig.
Though of course make sure that your machine can handle any upgrades you think of beforehand. For instance, throwing in another graphics card for Crossfire/SLI isnt possible on this rig, the PSU is too small and the mobo doesn't support dual Crossfire/SLI adequately.
m
l
a b B Homebuilt system
December 3, 2012 7:15:07 AM
I wouldn't throw $120 away on a dual core processor and turn around next year and buy a decent quad core. why not add $60 and buy it now instead of spending another $180 next year ? dual cores are next to useless.
m
l
