Hi and thanks for taking a look at this for me, I'm am amateur at best in building pc's I've put together this budget system and was wondering if you guys could look over it for me I would be very greatful if you could point out possible inadequacies or whether or not these parts are compatible. It may not look like it but ive put alot of research into this and still feel i am banging my head against a brick wall.
Processor - £91.36 - Intel Core i3 3220 Ivy Bridge Dual Core Processor - Retail
http://www.scan.co.uk/products/intel-core-i3-3220-s-1155-ivy-bridge-dual-core-33ghz-3mb-smart-cache-retail
Motherboard - £70.52 - Gigabyte GA-Z77-DS3H Intel Z77 Socket 1155 Motherboard
http://www.scan.co.uk/products/gigabyte-ga-z77-ds3h-intel-z77-s-1155-ddr3-sata-iii-6gb-s-sata-raid-pcie-30-(x16)-d-sub-dvi-d-hdmi-a
Ram - £30.50 - G.Skill 8GB DDR3 1600Mhz RipjawsX Memory
http://www.ebuyer.com/264750-g-skill-8gb-ddr3-1600mhz-ripjawsx-memory-f3-12800cl9d-8gbxl
HDD - £58 - Seagate 1TB SATA 3 Performance Hard Drive OEM ST1000DM003
http://www.scan.co.uk/products/1tb-seagate-st1000dm003-barracuda-720014-sata-6gb-s-7200rpm-64mb-cache-8ms-ncq-oem
DVD Drive - £13.18 - M-DISC Supported DVDRW the LG GH24NS90.AUAA50B
http://www.scan.co.uk/products/lg-gh24ns90-24x-dvdr-12xdvddl-dvdplusrw-x8-rwx6-12xram-with-m-disc-support-sata-black-oem
Case - Not Needed -
GPU - £174 - XFX 7870 Core Edition DD AMD/ATI Graphics Card - 2GB
http://www.scan.co.uk/products/2gb-xfx-radeon-hd-7870-double-dissipation-edition-4800mhz-gddr5-28nm-gpu-1000mhz-1280-cores
PSU - 30.54 - 50W Antec Basiq VP450P-GB 80 PLUS, EPS 12V, Quiet Fan, ATX v2.3, PSU
http://www.scan.co.uk/products/450w-antec-basiq-vp450p-gb-80-plus-eps-12v-quiet-fan-atx-v23-psu
Total - £466
I do not need a monitor or an OS, My budget is as close to £400 as possible not above £500. I will not be overclocking anything either.
Case - Not Needed -
Total - £466
