Solved
Will My PC work with This Grpahics Card
Hello, I am looking towards buying this Graphics card for my PC and would like some advice on whether It will actually work/fit. Many Thanks Guys, here are the specifications:
Graphics Card: http://www.amazon.co.uk/Asus-Radeon-Graphics-PCI-Express-Dust-proof/dp/tech-data/B004XANO24/ref=de_a_smtd
My PC Specs: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01357175
Many Thanks,
Tryf.
3 answers Last reply Best Answer
More about will work grpahics card
  1. Best answer
    What it mostly depends on is if your PSU can handle it. If not, that card doesn't take much power and a PSU that would be able to handle it should cost less that $50 easily. AM2 CPUs are pretty weak, but so is that card so they'd probably work pretty well together.
    Great Help Mace, thanks for the speedy reply. :D
  3. Best answer selected by tryfan.
Graphics Cards Graphics
