Hello homebuild experts,
I have recently acquired 2 Tesla K20 NVIDIA GPU and I need to host them.
My computational needs are:
*) LINUX.
*) running my own neural network (NN) code in C - usually i have 10s or even 100s of different independent neural networks to run.
*) a lot of text processing for preparing the input and output data files (100 megabyte max each) using sed, awk, grep and other unix command line cmds. Preprocessing is glued together with perl or bash scripts.
*) Plotting data using R or gnuplot.
*) Maybe MySQL database but that can go on separate dedicated box.
*) No fancy graphic needs or video streaming etc.
The most intensive app is the NN code which I plan to port it to the GPUs.
What I have in mind is to use the GPUs for running the NNs and the CPU for text-processing, R or gnuplot as thus:
The pipeline (as a perl/bash script) starts on a single thread on the CPU, process the data files and writes them to temporary files to the hard disk or Linux ramdisk, then runs a NN by spawning portions of code to the GPU, etc. (not sure yet about this). When NN finishes, results are processed again on the CPU and hard disk, ploted etc. and the pipeline finishes. I can have many pipelines running in parallel on the available threads of the CPU.
I don't use commercial, closed-source software, meaning that my pipelines/code can utilise all the threads of my CPU by either running separate versions of the same software on each thread.
Alternatively, I will run a single C program using pthreads to spawn functions in parallel (i say this because a lot of CPU benchmarks run single-thread tests and multi-core processors do badly for their price) which will need to read huge shared memory and sending back small-size results using say MPI.
So in either way, I have high utilisation of threads on CPU and have portions of code which can go to GPU. I write my own C programs and maybe I can get compiler to use the extra AMD instructions for more efficiency.
Since I am constrained on money and space and watt, I would like to build a single workstation on a single motherboard hosting 1 or 2 or (max CPUs?) high-core cpus (e.g. AMDs FX-8350, 8cores, 155 uk pounds) and large memory (max RAM?)
CPU:
For the reasons above I would like CPU to give me lots of threads, and be cheap. I thought the AMD FX-8350 had price i could afford for what I got according to the benchmarks (e.g.
http://www.cpubenchmark.net/high_end_cpus.html#cpuvalue). The Intels were ridiculously expensive (actually the AMDs ridiculously cheap).
Do any of you experts of homebuild systems have some serious objections about the choice of CPU? Would you prefer an Intel 4-core, say i5,
which is only 10% more expensive?
Based on the choice of the AMD FX-8350 (or your suggestion), can you please suggest:
1) MOBO: a lean, mean, cheap one which can host 2 NVIDIA GPUs (SLI may come handy) and ideally to have on-board simple GPU for the needs of the OS (Linux, no games, no fancy apps, etc.), simple network and sound cards, support for 2,3 3TB hard disks (say sata 6GB/s?) and top-of-the-range USB data transfers for adding external data storage if need be AND max data-transfers to the GPU cards. Is there a mobo to be able to host 2 AMD CPUs? (no overclocking, no fancy gimmicks for me, just fast transfers and max slots).
2) PSU: each K20 GPU has max power consumption of 225W. The AMD FX-8350 is at 125W. So depending on 1 or 2 CPUs, I think 850W or 1050W? Then XFX or Corsair Enthusiast depending on cheap deals at the time. Any objections/suggestions?
3) COOLING: the GPU cards come with their own fan. Do I need extra cooling you think? Will computer case standard fans (say 3, plus PSU's) be enough? I can install extra fan. Do I need water cooling? I do intend to run the system in hot climate, summer is about 35C=95F. Is water cooling cheaper at the end, more quiet and *safe*?
4) Hard disk, good for money i thought is the Western Digital 3TB RED 6GB/s at 130 uk pounds, but I am open to suggestions, it also depends on if any deals come up.
5) RAM: I would like to go for the maximum RAM I can slot on that board and be fast ram at that (1066?). Of course price is still an issue, but I can utilise all the RAM by creating linux ramdisks and storing temp files there.
Please tell me your opinion about using 2 or more cpus on the same board. I guess some of you may suggest a cluster of workstations also in view of the fact of acquiring an extra 2 GPUs, but then we get into other problems of power and space. (is there a high-end solution, e.g. servers, to this which is affordable?)
I live in the UK and usually buy from
http://www.dabs.com
BTW, I saw one of you mentioning in another thread, overclocking errors will kill the scientific computing results, so no over-clocking for me.
Many thanks,
Bliko
