Sign-in / Sign-up
Closed
Will hd radeon 7770 work on pcie 1
  • Radeon
  • Graphics
Last response: in Graphics Cards
October 13, 2012 6:10:19 AM
Hello,
i am using asus motherboard ( P5KPL-AM/PS ).
I just want to kwow will amd redeon 7770 work on my pc. my specs are:-
Intel core 2 quad q8200 @2.33 GHz
ram - 4 GB
PSU - 450 watts ( i Ball )
More about : radeon 7770 work pcie
October 13, 2012 6:32:29 AM
Well, the motherboard has a pci-e slot and the 7770, requires a minimum 450 watt psu, with a six pin power connector. You should be good.
Score
Best solution
October 13, 2012 6:36:47 AM
Welcome to Tom's Hardware. :)
To be honest, you're PC is very outdated and ancient. The 450w of Iball is useless. The company is no good for gaming. Get a 550w or 650w of coolermaster or gigabyte. Upgrade to atleaset 8GB ddr3 ram @1600Mhz. Get a bulldozer FX4100 processor as its cheap and good. The P5KPL-AM/PS is veryy old. Get a GA-880GM-USB3 Motherboard as its cheap and supports 7770 with 2.0 PCIe x16.
Hope it works out. TC
October 13, 2012 6:54:16 AM
i agree with both
Score
October 13, 2012 7:02:09 AM
Best answer selected by mani88.
Score
October 13, 2012 7:20:19 AM
I am thinking of buying a new pc with following specs----
Intel core i5 3550 ( 3re gen. ) @ 3.3 GHz , turbo boost 3.7 GHz
ASUS P8H77-MLE Motherboard
8 GB ram @ 1600 MHz ( gskill )
1 TB WD Caviar Green HDD (WD10EARX)
Samsung 21.5 inch LED - S22B370H Monitor ( 1920 x 1080 pixels )
PSU - PLEASE RECOMMEND
Score
October 13, 2012 8:43:10 AM
Can u tell me from which country you are so i can recommend perfect PSU for your PC on ebay or flipkart.. Tc
Score
October 13, 2012 8:44:33 AM
This topic has been closed by MouseMonkey
Score
