Philips E118405
CDD 4801-33
CD-R/RW 8x4x32
Does anyone have an Idea? I have a CD-RW that a friend bought on an online auction it claims to be a Phillips model OEM. He attempted to install it without success so now it is my turn.
After installation and inserting a variety of disks as a test, the CD-RW locks up and the read light blinks continuous, a reboot is then necessary.
I installed it on the secondary IDE channel as master and used auto detect in the bios, I tried all of the other combinations (jumper to slave and auto) with the same result.
In the device manager it is correctly Identified and functions, I unchecked Auto insert notification, Disconnect is the only check box checked.
I was unable to find any particular match for this CDR-RW at the Philips web site, thou I wasted more than an hour searching there.
If any one has ideas please get me to the next step..
Thx...Patrick
CDD 4801-33
CD-R/RW 8x4x32
Thx...Patrick
