Need Advice in $460 build
Approximate Purchase Date: this week
Budget Range:460-500
System Usage from Most to Least Important: gaming, surfing the internet, watching movies
Are you buying a monitor: No
Parts to Upgrade: CPU (please tell in only intel cpus,i will prefer 'i' series)
DDR3 RAM
Strong graphics card
Power supply
500gb Hard disk
ASUS motherboard only
Do you need to buy OS: No
Preferred Website(s) for Parts: flipkart.com india
Country - India
Parts Preferences:I would like to upgrade to Intel CPU)
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: 1366x768
Additional Comments: It should be able to run GTA 5 in medium settings
4 answers Last reply
More about need advice build
  1. Why only ASUS motherboards? Gigabyte and Asrock make awesome motherboards aswell.
  2. ok then suggest in asrock,asus or gigabyte.
    but reply me the config
  3. Look at this
    http://pcpartpicker.com/p/qVhb
    it is a little closer to $500, but it is money well spent and has a nice upgrade path.
  4. PLZ REPLY FRIENDS,
New Build Systems
