Solved
6-Pin power cable doesn't fit
I have a GTX 260 that I'm trying to hook up to my Frankenstien PC I've just put together. The PSU I have has a weird cable though, one of the pins on the 6-pin connectors is square:
http://imgur.com/2Aaro
http://imgur.com/ChTBn
and doesn't fit into the "D" shaped hole that it corresponds to:
http://imgur.com/Anlu3
Note: this card requires 2 6-pins, and both are in the same situation.
Thanks for you time and insight.
More about : pin power cable fit
Graphics card Master
as you did not post the power supply your using. check all of the cables. if it a modular power supply. there going to be one 8 pin cable or two 4 pin cables to make up and 8 pin cable for pci power. if the power sdupply has two power cables most times there a 6 pin cable and 2 pin cable on one end and a 6 pin connector that polugs into the module power supply.
http://cdn.head-fi.org/5/56/56ff61d3_pcie-connectors.jp...
Related ressources
Unfortunately due to the nature of the beast (I got all these parts for free) I have very little information about the power supply, apart from the brand name is "Acepower", the model is ACE 520w, and that in it's previous life it was used in a graphics workstation.
Graphics card Expert
If you ACE 520W power supply is model PSUACE52012CM it doesn't have any PCI-Express power connectors.
You can see it's specs and model number by looking at the label affixed to the power supply showing the DC Output table etc etc.
Is it this one?
http://www.box.co.uk/520W_Ace_Value_Grey_PSU_24_Pin_wit...
lol i'm sure you can free up 2 molex connectors! if you need them for fans then you've probably got some 3 pin fan connectors on your motherboard that you could use for the fans
So the good news: I have 5 molex connectors.
The bad news: I'm using two of them; one for the Disc drive, the other two power a SATA hard drive Via adapter because the previous owner dcided to clip the ATA connectors to be unusable.
I do have soldering skills, and the old 300w psu that had SATA connectors. Could I replace the connectors by clipping off the old one and soldering a new one on?
Ask the community
