Will gtx 550 ti be bottlenecked by my system ?
vicky103
Specs are : amd athlon 64X2 5000+ dual core @2.60ghz
Ram 4gb ddr2 800
Monitor at res. 1024X768
Is gtx 550 ti good for my pc ?
your cpu will hold you back a lot and you won't be able to play many games very smoothly no matter what graphics card you buy. I suggest either upgrading everything soon or buy something less expensive.
What other choices do you have?
